Trade: trim,paint,clean
Primer Issue
does good drywall work need primer? Two coats of good paint seem to be working well so far, but the issue has come up while interviewing with a builder.
Back from the dead...
Trade: Paperhanger/Painter
Re: Primer Issue
Builder's never want to pay for primer.
I believe all new drywall/joint compound needs to be primed. I get tired of seeing paint failure's due to builders being cheapskates. |
Re: Primer Issue
What will happen if not primed?
Re: Primer Issue
All possibles:
flashing stain bleed through adhesion failure multiple coats required for coverage Read this. |
Trade: Hanger taper finisher painter
Re: Primer Issue
If your final coat has a sheen to it you should use a primer. To fill the sponge (drywall/mud) with primer and not paint. Primer cost less than paint. It should. If it doesnt your paying to much. Primer for drywall that is. Blowes ... I mean lowes sells first coat by valspar for 40 bucks per five gallons. I get a drywall primer for 29 dollars at Rodda. If you use a paint with a glossy sheen you may end up with inconsistent sheen.
Trade: painter
Re: Primer Issue
Using a quality primer also evens out the texture differences between the paper face and the finished joint on the drywall. As far as the price goes, my exterior primers cost just about the same as the paint, but the time I save on call backs after a couple of years is definately worth it. Quality materials = quality jobs, why do it half a$$ed?
#7 | ||
...jammin
Trade: Rock Disciple
Re: Primer IssueQuote:
Always It's for adhesion purposes, among others Just because the paint won't always fail immediately on-primered drywall, that doesn't mean it doesn't need it Quote:
Hey, don't get me wrong More work for me ya know But telling the proud owners of a three years old home/remodel that the reason their paint is failing is that their builder hosed them on the paint job by not priming, it's just sad really And now they are going to have to pay me extra to fix it |
Professional Remodeler
Re: Primer Issue
I agree 100% with Slickshift -
You can put two coats of paint on an old sh**wagon and it will look great - for a while. In the professional world, primers and not an option, but a necessesity for a proper job. |
Re: Primer Issue
Hi,
The real question is whether or not you need a PRIMER or a SEALER. Simply using a primer does NOTHING to guarantee evenness of a coating. Primers are used to fill in imperfections and have low resins, allowing finish coats to grab the primer. Sealers are used to stop paint form being absorbed unevenly, allowing for an even finish. Sealers have high resins, low pigment. There is a big difference between primers and sealers and every painter should know this. Now, if ya go with a good PVA primer/sealer...you should be golden... Thanks. Harry |
Re: Primer Issue
Wow, thanks guys. I'm glad I learned this early on. I'll get after my builder to spring for a prime/seal. Will a good paint ever cover well enough in 1 coat after sealing? We deal with SW.
thanks again...love this site, cindy |
#11 | |
...jammin
There's no such thing as a true one-coat paint If there was, we'd be all over that ![]() well, you may be able to "get away with" one coat at times, but it is "getting away with" it, and all that that implies It'll also be in a sort of "looks OK" sort of way rather than "just like the swatch" way |
Re: Primer Issue
OK, so that leads to the next question or questions...
can have my primer tinted?...so as not to have to put on a 'primary prime/seal' coat?...and/or should I be charging a little more for a primary coat. I'm in KY and I think 1.25 /sf is pretty good for our quality. I'm thinking a coat of seal would take about 4 hours more per thousand/sf. Again, new here and thanks espesially to slick for the feedback. |
Trade: General Renovations
Re: Primer Issue
Hey all
Cynthiann, you read my mind in tinted primers. What do the pros think? I have had really mixed results - some great, some nightmares. Also, is there a particular brand of primer/sealer you would recommend over the others? I have used BM Fresh Start over the years with some pretty good results. Is there a more "pro-oriented" brand I should be looking for? Cheers, Graeme |
#14 | |||
...jammin
I don't Maaaaybe I might go gray with some of those deep colors...maybe Really SWP Deep Accents kinda blows the need for that, BM maybe I'd grey up the primer on a deep red or something Other than that I don't see the point, unless you're trying to only do one color coat (top coat) Besides, once it's tinted, I can't use it on any other projects, like my house Quote:
New Drywall I tend to use a primer/sealer or plain primer-tinted or not That's one coat Then two color coats That's pretty standard Quote:
Yes, the primer coat always takes longer to apply, the top coats less |
...jammin
Re: Primer Issue
Hey Graeme, Nice Avatar!
Fresh Start? For new drywall? Yeah that should work, seems a little overkill to me But I've found for new drywall the Pittsburg SpeedHide Primer/Sealer really kicks butt for a "contractor-grade" product Really it holds up to the best I've used for non-problem new drywall, and it's cheap I know I'm always "cheap paints and tools don't save you money... blah blah...", but I really am a cheap bstrd lol I have been known to rinse out my tray and pot liners |
#16 | |
#17 | |
The past 2-3 years, I've been priming garbage flat with Gardz or DrawTite, which seems to penetrate more and alleviate the problem. Read this article, it explains it nicely. |
#18 | |
#19 | |||
These were up high, on vaulted walls, and ceilings. same fialure, only not as big. I really can't be certain why they failed, only assume it got hot and dry up there, and eventually the bond crumbled and failed. Quote:
#20 | |
...jammin
Re: Primer Issue
Good discusion
I'd just like to comment on Quote:
Ever That's my point You'd have to have been doing re-paints/wall-coverings for the last 20 to see it |
| Drywall primer peeling problem?? | DeanV | Painting & Finish Work | 23 | 02-02-2008 11:02 AM |
| 2 coats of primer on ceiling rather than paint? | Zeebo | Painting & Finish Work | 20 | 12-25-2006 01:05 PM |
| Tinting primer question | icfbunt | Painting & Finish Work | 5 | 12-12-2006 06:44 PM |
| Primer needed on metal garage door??? | Zeebo | Painting & Finish Work | 11 | 08-19-2006 05:35 PM |
| alkyd primer or not | cowtown | Wallpaper | 8 | 08-11-2006 12:46 AM |
