Which Primer? - Painting & Finish Work - Contractor Talk
Which Primer?
Old 04-21-2013, 09:19 AM   #1
Derek1157's Avatar
Trade: Painter/Remodeler/Funnyman
Rewards Points: 81
Which Primer?
I have a house here that has iron in the water/soil. I'm going to topcoat with Duration Satin, but I want to seal this staining first. I'm interested to hear what other people would use. I'm thinking about a fast dry oil primer, as it's still humid out here. Think I could use a latex sealer? Thanks!
Derek1157 is offline
Old 04-21-2013, 10:27 AM   #2
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,016
Re: Which Primer?
You're taking a chance with latex. Even though I believe they are perfected now for many apps.
Its not a big area. I would use Cover Stain oil base. Then I will know I have done the best job I could.
You only need a couple hours in the PM to do it.
What kind of siding is that ? Masonite (no bead) ? Don't use latex.
We Fix Houses is online now
Old 04-21-2013, 10:29 AM   #3
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Re: Which Primer?
I like Zinsser but the latex doesn't seem to be the best stain blocker. Judging by the looks of the stain I would want to use oil based for sure.
CrpntrFrk is offline
Old 04-21-2013, 01:23 PM   #4
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 18,325
Re: Which Primer?
As bad as that stain looks. It won't bleed thru no where near the way it would if that same color water stain was on a drywall ceiling from a roof leak.
I think a latex will seal it just fine with no bleed thru.
-Paul
TextureMaster.com
Checkout my YouTube Channel with 25,000 Subscribers and over 6,000,000 Views
https://www.youtube.com/paulpeck
Twitter Facebook Google+ Instagram
Sir Mixalot is offline
Old 04-21-2013, 02:36 PM   #5
Remodeler
TAHomeRepairs's Avatar
Rewards Points: 574
Re: Which Primer?
I would clean it with muriatic acid solution. Its rust from sprinklers, right? No stain, no bleed through. my .02
TAHomeRepairs is offline
Old 04-21-2013, 05:34 PM   #6
Pete'sfeets's Avatar
Trade: house painting and miscellaneous repair
Re: Which Primer?
If they can't come up with something to stop the splash up why bother at all. Exterior paint should be able to cover, not ceiling paint tho
If paint covers all sins ,,,then I guess I should be covered
Pete'sfeets is offline
Old 04-21-2013, 07:03 PM   #7
Remodeler
Rewards Points: 574
Re: Which Primer?
Agreed, adjust the sprinkler heads afterwards.....
Old 04-21-2013, 08:31 PM   #8
Derek1157's Avatar
Rewards Points: 81
Re: Which Primer?
I believe it is the sprinklers. HO said he was having it fixed/altered so that it won't happen anymore. Not sure what he's doing, but hired me to cover it anyway. It's cement board siding. I think I'm going to do the oil primer. I don't really want to mess around with acid. It's on all sides of the house. This is the worst though. Going to be painting the house all this week, so will post some pics later on. Thanks for all the input.
Old 04-21-2013, 08:45 PM   #9
Remodeler
Rewards Points: 574
Re: Which Primer?
Vinegar may do it too.
Old 04-21-2013, 10:44 PM   #10
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,426
Re: Which Primer?
No question, I would prime with zinnser coverstain tinted to the color of the top coat.
SuperiorHIP is offline
Old 04-29-2013, 03:53 PM   #11
Caslon's Avatar
Trade: State Licensed Painting Contractor
Rewards Points: 1,340
Re: Which Primer?
Or CLR. Its not that big an area, one quart applied with a garden sprayer and scrubbed should remove enough to allow a good water based primer to work, but why not use an oil based or shellac primer and forgo the cleaning part? (again, its not that big an area). You could use a Bullseye latex primer, but it might take 2 coats.
Caslon is online now
SW Prewallcovering primer to be discontinued Ohio painter Wallpaper 7 05-12-2013 08:51 PM
Best Waterbased Primer - Sanding - TBFGhost Painting & Finish Work 5 04-01-2013 08:19 PM
A Shiba Inu Primer hdavis Off Topic (Non Trade) 7 12-20-2012 07:37 PM
Latex Primer over Poly Urethane?? DemRem Painting & Finish Work 32 08-19-2012 03:32 PM
can't get rid of bad primer smell....help please Zeebo Painting & Finish Work 17 12-10-2008 06:39 AM
