Prime Sound Exterior Surface.
Old 10-07-2007, 02:14 PM   #1
Hudson Valley
mjay's Avatar
Trade: Restorative Painting
Have customer that insists on priming his western red cedar that has already 1 paint sytem applied [Primed and two finish 6 years old]. Paint is in good condition: No flaking, no blisters, and firmly adhered to substrate.
My proposal is to clean exterior thoroughly, light sand, and apply two coats of California Velvet Exterior.
Is there any benefit to applying an acrylic prime coat to an already sound surface?
www.blueskiesrestorations.com
There's some top class people on this forum,........and then there's me...Touching cloth.
mjay is offline
Old 10-07-2007, 04:24 PM   #2
plazaman's Avatar
Re: Prime Sound Exterior Surface.
i havent had any experience with cedar, but i think you would use an oil primer instead
plazaman is online now
Old 10-07-2007, 06:49 PM   #3
jackrabbit5's Avatar
Trade: Paperhanger/painting contractor
I can think of no reason to prime other than the fact that your customer insists upon it. And the customer is always right . The primer, while unnecessary, certainly won't hurt anything, so give the customer what he wants and charge accordingly.
Stacy
S B Bolson & Sons
jackrabbit5 is offline
Old 10-08-2007, 12:42 AM   #4
Hudson Valley
mjay's Avatar
Thanks for the replies. After some research, come to the conclusion that there is no benefit to prime sound surface, and there may be a disadvantage to adding an un-necessary extra coat.
Western Red Cedar Association has some good info.
mjay is offline
Old 10-09-2007, 08:27 AM   #5
PlainPainter's Avatar
you'd prime - if you wanted to radically change the color. Like going over a deep red with a light tan. In that case you might try tinting the primer to the color you want - and hopefully one topcoat provides a perfect coverage. What would you sand, not all the siding I hope?
PlainPainter is offline
Old 10-09-2007, 08:26 PM   #6
...jammin
slickshift's Avatar
Trade: Rock Disciple
Nope
Signature Quote
slickshift is offline
Old 10-10-2007, 08:17 AM   #7
Give her what she wants - pressure wash, scrape, sand, spot prime wood with oil, caulk - then one coat of a tinted exterior latex primer, and then one coat of california topcoat. Who knows you may discover something interesting about the final product.
Old 10-10-2007, 08:37 AM   #8
Hudson Valley
mjay's Avatar
When I was 18 I made the mistake of working to the owners specs. All I heard was complaints: Lesson learned - Do the job the only way/ the right way and you will sleep soundly while the customer admires your craft.
mjay is offline
Old 10-10-2007, 08:43 AM   #9
Hudson Valley
mjay's Avatar
mjay is offline
Sound Proof Common Wall bbbuilders Construction 8 10-25-2007 02:13 PM
New outside trim....to prime or not to prime Flikka Painting & Finish Work 11 07-06-2007 07:15 AM
prime before texturing...just do it Richard Painting & Finish Work 9 03-27-2007 09:12 PM
prime marks on wall lornmastro Painting & Finish Work 37 11-12-2006 03:12 PM
prime or not to prime trumps101 Painting & Finish Work 4 04-09-2006 09:44 PM
