Organic Painter
Trade: Painting Contractor
Prime Or Not To Prime Before Glazing?
Does all glazing and windows require this priming before glazing?
I am not 100% sure we have to prime first, I will count on one of you to do the research |
Re: Prime Or Not To Prime Before Glazing?
Uuuh, trust me, I've done
better than "research". ![]() Prime it!
A bit abrasive.
Re: Prime Or Not To Prime Before Glazing?Better listen to neolitic, he saw a painter on television do it once... ![]()
My advice: Hire a real painter to do it. |
| The Following User Says Thank You to WisePainter For This Useful Post: | Jason Whipple (05-04-2009) |
#4 | |
Re: Prime Or Not To Prime Before Glazing?Quote:
get burned that way...... once....... long, long ago..... in a galaxy far, far away......
Capra aegagrus
Re: Prime Or Not To Prime Before Glazing? |
Organic Painter
This painting is just not as easy as it looks huh?
#7 | |
only too true. And the second time on the first set was waaaaaay too soon.
Capra aegagrus
Organic Painter
My research is in:
The rep told me that not priming the surface is O'k. It will be harder to install the glazing and the wood will dry out the glazing quicker than if we prime it first, however not priming the wood first will not hurt the sticking power of the glazing. I use glazall or what ever the name is from SW. |
Trade: commercial building restoration
what is the dry time of the glazing before you can coat it:
Primed vs not primed? |
Affect sticking power? Maybe not, but will it seal moisture out? Or will it let moisture seep under the glazing and into the unsealed wood?
I' ve never given it that much thought, just always primed and glazed the few I have done. Not sure how priming makes it harder to glaze either if the primer is dry. |
Trade: Painting - Restoration
The glazing has oils in it so either way its going to take time to dry...
Prime the seal... it protects the wood when the glaze fails later on down the road. |
paper hanger,painter
Was he from SW?? |
Restoration Crazy
For best results, read the directions on the side of the can (unless you think you know more than they do)
Jason E Whipple, General Manager Historic House Restoration, Cincinnati, Ohio Facebook | Twitter |
LRG WoodCrafting
prime it. or pay later.
Trade: siding
shouldnt all raw wood be primed?just seems like good practice
Trade: painting
What about the market. If no one else around is priming first can you afford to put it in your bid? If you tell them they need to do it and the other 4 contractors tell them whomever told them that "they are just trying to squeeze every dollar they can out of you" then what do you do. Is priming before glazing so important that you wont not do it? I personally feel that priming bare drywall is more important but I see people use 2 coats of the cheapest flat they can find all the time. And Im with Mike, if it was so important then why wasnt it done the first time. I have never seen glazing fall out or cut out that was primed prior.
| The Following 3 Users Say Thank You to capital city For This Useful Post: |
#18 | |
vandy
Trade: painting, decorating, wallcovering
this may be an instance where you'd give them 2 bids. one for the way most guys do it. another for the right way that you would do it. who knows ? i have rarely seen a guy walk away from a job because he couldn't do it his ideal way. we give them what they pay for. especially when the pickens are slim. |
#19 |
Organic Painter
The can does say for best results prime first, so I called the SW rep he called the tech support at the glazol place and caled me right back.
Primed or not before glazing there will be no way for moisture to seep under the glazing. |
#20 |
Trade: Drywall, Modulars, Remodeling
| Should I prime these soffits or just paint? | Entrepreneur | Painting & Finish Work | 23 | 04-19-2009 07:50 PM |
| Prime and Texture over painted splatter ceiling texture | AARC Drywall | Drywall | 2 | 03-13-2009 08:53 PM |
| Help pricing prime coat | IBEX Drywall | Painting & Finish Work | 25 | 01-10-2009 03:30 PM |
| Need help with glazing walls | BCJones | Faux Finishes | 1 | 08-25-2008 05:43 PM |
| prime marks on wall | lornmastro | Painting & Finish Work | 37 | 11-12-2006 03:12 PM |
