Prime Marks On Wall
Old 10-25-2006, 09:50 PM   #1
lornmastro's Avatar
Trade: interior paint contractor and window treatment workroom
Prime Marks On Wall
ok....just need to check with my pro friends....painted a home...new construction previous painted by builder...really dry walls...did some spackling...primed those spots..painted the walls with 2 coats of satin with BIG window on far wall....could still see the prime marks...so put 2 more coats of paint on wall....still can see prime spots.usually after 4 coats of paint these prime spots disapear....was it the satin paint...that damn big window that shows everything or should i have primed. .....and do you always prime homes that still have builder paint on the wall??
lornmastro is offline
Old 10-25-2006, 10:24 PM   #2
My custom title
Brushslingers's Avatar
Re: Prime Marks On Wall
Whatcha prime it with?
Benn
Originally Posted by Brian
Brushslingers is offline
Old 10-25-2006, 10:25 PM   #3
Teetorbilt's Avatar
My question too!
Albert Einstein
Teetorbilt is online now
Old 10-25-2006, 10:30 PM   #4
...jammin
slickshift's Avatar
Trade: Rock Disciple
Me too
And I know you like to use SWP
Which one was it (for the paint)? or was it something else?
Signature Quote
slickshift is offline
Old 10-26-2006, 12:06 AM   #5
BMAN's Avatar
Trade: Painting & Remodeling
I like to prime repairs with the actual paint that will be the final coat. I have found that some primers do chnage the sheen of the final coat. Like Kills oderless for one.
BMAN is offline
Old 10-26-2006, 12:23 AM   #6
Teetorbilt's Avatar
My last post of Yesterday. WTF?
Albert Einstein
Old 10-26-2006, 07:10 AM   #7
Professional Painter
Richard's Avatar
Trade: Owner/Operator
Huh???
I use a primer to prime, not my finish paint.
Sometimes I'll quickly go over the primer spots with finish before I cut the wall in, but never just the finish over the repair. That's asking for trouble.
Rich
Richard is offline
Old 10-26-2006, 09:38 AM   #8
lornmastro's Avatar
i used kilz orderless and then painted with sw..super paint....yiks i guess kilz is the culprit??what is the fix for this problem??
Old 10-26-2006, 12:13 PM   #9
shermanpainting's Avatar
Did you check it after full dry time. I have seen this before but after full cure it went away.
shermanpainting is offline
Old 10-26-2006, 02:50 PM   #10
Timmy's Avatar
Trade: custom closets
I ve never had luck spot priming a repair with a kilz product. I would have used SW pro-Block over the entire panel tinted the same as the top coat.--not spot priming. Too many problems as you see, especially with a satin or egg-shell. Too fix this I reccomend overprime the entire panel, tinted same as top and cover with the top coat. Problems should dissappear.
Timmy
Timmy is offline
Old 10-26-2006, 03:36 PM   #11
Pro Painter
AAPaint's Avatar
Trade: Painting Contractor
Good advice Timmy. That's pretty much how I would do it. However, if you're spot priming and using paint with a sheen, next time try Zinsser's Gardz on it. It's a sealer and will even out the porosity of the substrate in that area so you don't see the flashing. Werks good.
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 10-26-2006, 07:37 PM   #12
...jammin
slickshift's Avatar
The only Kilz product that works is Original Kilz
The rest stink on ice
And that chalky builders paint can be a problem
I like to prime that with Gardz
To avoid putting 4 coats paint on the problem areas, you might try re-priming (spot) with a better primer, but you still should do two coats of paint over that
You may be better off 'spot priming' with the paint you are using to get extra coats on the problem areas w/o any flashing issues
(Not sure how SP works with that kinda stuff, with BM AquaVelvet that would work fine)
Signature Quote
Old 10-26-2006, 07:47 PM   #13
KellyPainting's Avatar
What colors?
buiders colors....
primer color... White?
your color...(satin)?
medium base or deep base ?
KellyPainting is offline
Old 10-26-2006, 07:59 PM   #14
Mike Danahy
Danahy's Avatar
Trade: Signature Painter
I will spot prime with the finish paint twice on anything the size of a penny, or smaller... If it's larger, I bust out the cover stain to avoid any frog eye, or bubbles.
Danahy is offline
Old 10-26-2006, 09:21 PM   #15
Joewho's Avatar
Trade: Painter
I think some of the primers dry so that they are actuallly smoother than bare drywall. I usually hit them with sand paper before painting.
Joewho is offline
Old 10-26-2006, 10:29 PM   #16
SgtBaldy's Avatar
is it the primer your seeing flash or did your patchwork just suck. No priming will hide that.
Tampa Painters
SgtBaldy is offline
Old 10-26-2006, 10:34 PM   #17
My custom title
Kilz, four coats.. umm, was the orginal coats sprayed? Sounds like a spray job with no backroll. I mean, oil kilz or even the latex shouldnt flash after four coats... unless you just suck at painting.. heh. Or as baldy said, whats the texture on the walls?
Benn
Old 10-26-2006, 10:50 PM   #18
Pro Painter
AAPaint's Avatar
Didn't think of that one. If it's severely orange peeled, then patched and the patch is smooth you'll get the same thing.
-AAPaint
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 10-26-2006, 11:06 PM   #19
lornmastro's Avatar
first off you folks are the best..big smooch to all of you.so many questions to answer....the original color was builder off white sprayed ...the paint was a medium base sw blonde satin finish...it definitely was not the spackle spot because it showed up as square boxes......i primed with a roller..it didn't fully cure it was only a day old
now my questions Gardz...the same stuff i use for sealing sheetrock that has been damaged?
i was always told that i need to prime bigger spots because the paint won't adhere to the spackle...true or false??
so your saying in a situation with larger spots i should prime the whole wall...or the whole area...not just the 3 x 3 spots...or could i just prime the area spackled with gardz
"i bust out the cover stain to avoid any frog eyes"...what the heck does that mean??
DOES ANYONE WANT A CAN OF LOW ODER KILZ???
Old 10-27-2006, 02:58 AM   #20
painterofeverything
painterofeveryt's Avatar
Trade: residential painter
Send a message via Yahoo to painterofeveryt
if it was my job,I would prime the whole wall,,paint the whole wall...just my two cents.
painterofeveryt is offline
Load bearing wall or not??? BMAN Remodeling 26 07-28-2008 07:16 PM
Backyard office, retaining, and privacy wall Team Scream Masonry 8 08-02-2007 11:27 PM
moving centennial wall stacker Masonry 4 10-20-2006 12:12 AM
Roller marks in dark paint. cutnroller Painting & Finish Work 10 08-03-2006 11:09 PM
