Presure Treated Wood And Staining????
New deck built last fall, hasn't been stained yet. My question is this, does the PT need to be completly sanded before the primer and stain can be put on?
Thanks, Sellncars |
Painting Contractor
Re: Presure Treated Wood And Staining????
you should clean and sand... no need to use primer with stain...
painterofeverything
Just wondering...why should he sand it?
Painting Contractor
sanding will get rid of the dead wood cells, splinters, ruff edges, mill glaze (if any), allow the stain to provide a smooth uniform finish...
Chief Toilet Mover
Trade: Bathroom Remodeling
Couldn't you get good results using a wood brightner instead?
Me, I would just clean it with Simple Green and use Penofin for PT on it and sit back and admire the results as I drank a Mohito.
#6 | |
Pro Painter
A good brightener will clean the wood, help with any grey or green discoloration, and remove dead wood fibers with a light (800-1000 psi) power wash. I'd hit it with some timberbright pro wash it down lightly, let it dry, and stain it. I would skip the penofin and go straight to ready seal though.....many pros in the wood care sector consider penofin good food for mold because of the rosewood oil.
painterofeverything
sanding would actually make it stain more blotchy.....
#8 | |
...jammin
Trade: Rock Disciple
Cleaner and brightener
Usually no sanding
Signature Quote Quote:
#9 | |
Chief Toilet Mover
Re: Presure Treated Wood And Staining????Quote:
Anyways, it matters little to us in Colorado with humidity about -20% mold is not an issue out here no matter even if you were feeding it intravenously with an IV.
#10 | |
Pro Painter
I have seen the results here in the south, and it's ugly....my experience isn't based on rumor. Many in the wood care field agree with what I stated probably because they've seen it too. Within a year or two around here penofin turns black and might as well be a petri dish.
Painting Contractor
Yes, I agree cleaner and brightener but...
"For new decks" I still sand just to remove some ruffness... not a deep sanding...just a light (quick) orbital sanding with 80 or 100... sanding is not a bad thing to do... its just an extra detailed step.. never had any blotchy issues... and my customers appreciate the extra step... |
#12 | |
...jammin
Sometimes it needs it
#13 | |
Chief Toilet Mover
Hi Guys,
When i went to the paint store, they told me that i needed the primer and the stain. Both are Benjamin Moore, which i always thought was a good name in paint anyways. It appears that alot of you don't ever primer a new deck before staining? The primer has color in it the same as the stain. If this is true why was i told i needed a primer? Good sales pitch by a decent looking chic? |
#15 | |
...jammin
You don't primer stain
The only exclusion I can think of is you might want to hit nail heads with a dab of oil primer before solid staining (rust bleed through) As I use oil solid stain that's not an issue with me
#16 | |
Pro Painter
I would look into another type of stain. There shouldn't be a primer for stain......stain soaks into the wood and, well, stains it to the proper color. Unless this is a film forming stain....there wouldn't be any need for a primer, and if it's a film former, you don't want it because it WILL fail.
