Old 05-04-2007, 07:52 PM   #1
Traditions's Avatar
Trade: painting
pressure washer
I am going to buy a new pressure washer tomorrow. i am in between a 3000 and 4000 psi. I am doing mostly decks, and small homes prepping for paint. Would i be good to go with the 3000. I have been using a much smaller pressure washer for years, don't really use one too often. Opinions please.
Traditions is offline   Reply With Quote
Old 05-04-2007, 08:01 PM   #2
...jammin
slickshift's Avatar
Trade: Rock Disciple
I've been using a 2800 for years
It's enough, but sometimes I'm pushing it
I'm not a full time p/w-er by any means
I use it prolly like you do/would
I'd say the 3000 should do it
I didn't step up to the next size because it was significantly heavier
I have to lift it up onto the back of the van, so...
Signature Quote
slickshift is offline   Reply With Quote
Old 05-04-2007, 08:01 PM   #3
My custom title
Brushslingers's Avatar
Look for GPM instead, unless your doing alot of concrete...
Benn
Originally Posted by Brian
Brushslingers is offline   Reply With Quote
Old 05-04-2007, 08:25 PM   #4
Traditions's Avatar
Trade: painting
whats a good gpm? Anything else to look for?
Old 05-04-2007, 08:58 PM   #5
...jammin
slickshift's Avatar
For a 3K psi? 2.5. 2.8
Belt drives supposed to be better
But mines a direct drive
Signature Quote
Old 05-04-2007, 10:21 PM   #6
My custom title
Ya, a 4k will push.. or at least can push around 4 gpm or more... shouldn't need something that big though unless you plan on buying a whisper or doing crete... my old 4k with a zero tip could cut a small tree down.
Benn
Old 05-04-2007, 11:22 PM   #7
Teetorbilt's Avatar
I'm also looking for input. My Troybilt is 2600 PSI but that is only with the 0 tip. Go to the 25* tip and the pressure drops to 1700, a little larger hole and you are down to garden hose pressure. My conjecture is low volume.
BTW, the little unit has done everything that I wanted it for. With the 0* tip, I'm sure that it would trim the bushes and trees.
Guage the tool to the job.
Albert Einstein
Teetorbilt is offline   Reply With Quote
Old 05-04-2007, 11:49 PM   #8
Trade: repairs, maintenance, improvements
I'm actually looking at buyin a new unit myself.
Does anyone know of an advantage of having a horizontal side mounted pump vs a vertical bottom mounted pump?
theartisan is offline   Reply With Quote
Old 05-05-2007, 09:20 AM   #9
Suck it up, or shut up
A great power washing forum www.thegrimescene.com
From what I understand the gpm is the important factor. you can get a lot of units wit6h anything from 1200 psi to 3600 psi but they only push about 2 1/2 gpm. the real cleaning is done with higher gpm.
I've been using a 2700 psi 2.7 gpm for a few years but when I see the right price I want a hot unit 4 to 5 gpm. any thing over 5 gpm requires additional water supply ( normal hose pressure is about 5)
rservices is offline   Reply With Quote
Old 05-05-2007, 06:50 PM   #10
bigchaz's Avatar
Trade: Wood Restoration/Refinishing
If you are doing decks, proper chemicals are important, not pressure
4gpm is recomended if you want to rinse at a decent pace. You could get away with a lower gpm but youll spend a lot longer rinsing the deck.
With wood, theres no reason to pressure over 1000 psi and you can throw the 0 degree tip out immediately.
Belt drive will keep the pump lasting much longer and allow you to draw from a tank if you dont have water supply. Direct drive will probably fit your needs fine as well though
Charlie Soden
ApexDeckSavers
Deck cleaning and staining Wake County
bigchaz is offline   Reply With Quote
Old 05-06-2007, 10:54 AM   #11
Trade: painter
Ditto, to what BigChaz said. I used to use a 3 gpm machine and upgraded to 5.6 gpm at the begining of last year for doing decks. Easily cut the time in half and for housewashes even more.
Sean Kennedy
St. Louis Painting Contractor
Kennedy Painting LLC
KENNEDY is offline   Reply With Quote
Replacement pump for pressure washer T bone Pressure Washing 5 08-01-2008 11:56 AM
What features/specs to look for in a pressure washer? steve-in-kville Painting & Finish Work 11 06-03-2008 01:17 AM
TSP & pressure washer Teetorbilt Painting & Finish Work 25 04-28-2008 04:28 PM
What size pressure washer and tip do I clean a deck with? jimb317 Painting & Finish Work 11 07-02-2007 12:43 AM
Pressure washer, which one? Dirtguy Pressure Washing 1 01-05-2007 11:46 AM
