Prep Wood Cracks For Varnish
Old 05-16-2010, 01:42 AM   #1
duburban's Avatar
Trade: building
Rewards Points: 1,276
I'm about to refinish a clients exterior deck railings. I stained and finished them a little over a year ago. I used Helsman Spar which held up ok at best. Volcano hawaii is a brutal climate, "like living on a boat". The varnish always fails first at the cracks in the wood. I'll be refinishing with Man O War spar this time and it is more flexable. Should i try to fill the cracks with epoxy, or spar, or leave them be? Thanks.
duburban is offline
Old 05-16-2010, 09:24 AM   #2
painterman's Avatar
Trade: Historic Restorations
Rewards Points: 288
Re: Prep Wood Cracks For Varnish
I would use Bristol Amber Varnish. Made for boat use. Very expensive but should last 3 years in your part of the world.
painterman is offline
Old 05-17-2010, 12:39 AM   #3
...jammin
slickshift's Avatar
Trade: Rock Disciple
Rewards Points: 2,000
Not seeing it it's hard to say if filling the cracks could look OK
If you can get it to blend in and look nice, you might want to
One of the keys to using these products in this type of environment (I'm sticking out into the North Atlantic here, not quite Hawaii but I can empathize) is to hit "all six sides"
Other-wise moisture creeps in and peels the varnish off like the skin off of a banana
Obviously, that's not always an option
Do you think moisture is seeping in though the cracked wood?
Another key is maint. coats
At least once a year
Maybe this one needs it twice?
And yeah Helmsman, though not a bad product per say, is generally regarded as a lightweight when compared to "real" spars and marine coatings for this app.
MOW is much better, and I can recommend Sikkens Marine also
Signature Quote
slickshift is offline
Old 05-17-2010, 07:34 AM   #4
New York City
eastend's Avatar
Trade: historic woodwork restorations
Rewards Points: 348
I'll second the use of Bristol finish (www.bristolfinish.com).
Also try penetrating epoxy sealer from Smith and company
eastend is offline
Wood floors in an elevated bay house (Texas) Monarchy Flooring 22 01-30-2010 12:01 PM
Drywall Cracks and Wood Burning Furnace mds120 Drywall 10 11-23-2009 10:08 PM
Best product for cracks in PT wood? JKRasku Painting & Finish Work 1 10-01-2009 10:32 AM
Thermally Modified Wood Live test results naturalwood Decks & Fencing 0 09-17-2009 07:06 PM
Alcove for Wood Stove Agolk2 Construction 0 09-02-2008 01:23 PM
