Preferred Acrylic Brushes
Old 09-11-2008, 12:06 PM   #1
HCPainting's Avatar
Trade: Brushworks
Last year I picked up a 100% polyster brush to compare with the nylon/poly blends. It was the first brush I literally wore out. The bristles wore down before they frayed. Before that and as a backup I was always impressed the Wooster Jaguar 3.5" straight contractor brush. Anyone have thoughts on polyster brushes or brushes that your crews are not allowed to borrow and subsequently destroy.
HCPainting is offline
Old 09-11-2008, 08:15 PM   #2
Dmax Consulting
Dmax Consulting's Avatar
Trade: Paint Contractor
Re: Preferred Acrylic Brushes
I have a purdy one that I love. It loads great and cuts straight lines!
Dmax Consulting is offline
Old 09-12-2008, 07:02 AM   #3
Doer of Many Things!!!
gideond's Avatar
Trade: Paint and Floor Covering Retailer
I don't particularly like Polyester brushes. I prefer nylon. But each has it's use. Ploy is better for exterior work as it holds it's firmness in the heat. Some of the new chemical tipping processes are making the bristles nearly as soft tipped as nylon now. However, it's a mess to get them clean in the newer aggressive acrylics. Nylon releases much better in the same paints and make cleanup much easier. I like the Wooster Soft line of nylon for the most part but I have to use the Xtra Firm line outside because nylon does softer up in the heat.
http://www.morrispaint.com
gideond is offline
Preferred exterior paint davidanbess Painting & Finish Work 20 09-27-2008 02:55 PM
Enamel over Acrylic Jason Whipple Painting & Finish Work 5 07-18-2008 09:12 PM
what type of brushes are preferred davidanbess Painting & Finish Work 27 07-23-2007 05:17 AM
100% acrylic vs waterborne technology DeanV Painting & Finish Work 3 03-30-2007 10:04 AM
Paint brushes RussellF Painting & Finish Work 7 09-27-2006 01:23 AM
