Pre Prime Painting
Old 06-09-2006, 03:02 PM   #1
Alkyd's Avatar
Trade: painter
Pre Prime Painting
I have some factory primed wainscoting to paint. The primer has a slick surface also like plastic. What is my prep for that substrate prior to painting? Can I just lightly sand then paint with analkyd? Thanks guys
Alkyd is offline
Old 06-09-2006, 04:36 PM   #2
...jammin
slickshift's Avatar
Trade: Rock Disciple
Re: Pre Prime Painting
Alkyd, are you sure that's "pre-primed wainscoting"?
It sounds like that fake stuff that comes in 4' x 6' sheets, is white, and is not meant to be painted
It really shouldn't be shiny, and I've seen no pre-primed wainscoting or beadboard that was
If that's what it is, they did you no favors by "pre-priming" it
It will have to be considered a "paneling"
I'd suggest a nice sanding followed by a solvent-based primer
Off-hand I'd suggest BIN shellac-based
It'll stick
Signature Quote
slickshift is offline
New outside trim....to prime or not to prime Flikka Painting & Finish Work 11 07-06-2007 07:15 AM
How profitable is your painting business? SeanATL Painting & Finish Work 13 04-21-2007 11:16 PM
prime marks on wall lornmastro Painting & Finish Work 37 11-12-2006 03:12 PM
Painting Question lunaassoc Painting & Finish Work 1 06-29-2006 09:34 PM
Painting as part of your estimate Mike Finley Remodeling 20 05-21-2006 11:25 PM
