Wet down the texture around the area that needs to be repaired...spray bottle should be sufficient for the area you mentioned; it'll keep the dust down if nothing else. Scrape off the texture without digging ALL of it out. It's okay to leave the base (1/16 to 1/8) of the texture on. If you don't leave it you end up with a sharp line underneath, even after a heavy coat of texture. HO may not notice it, but you will. Tape seams as you will, and spray. That small of an area I'd be tempted to try the can, make sure you close the area in. Spray goes everywhere you don't want it to. I've used Homex for orange peel match, but haven't tried it for popcorn. I tried the paint brush 'dab' method once. Once.
mark
