Popcorn Ceiling Removal ?
Old 06-02-2009, 11:05 PM   #1
CreativePainter's Avatar
Trade: Painter/Artist/Designer
Send a message via MSN to CreativePainter
What's the best way to remove never painted popcorn ceiling ?
Tks in advance !!!
CreativePainter is offline
Old 06-02-2009, 11:18 PM   #2
Organic Painter
Mr. Mike's Avatar
Trade: Painting Contractor
Re: Popcorn Ceiling Removal ?
Best thing you can do is run a search before posting a question like this, You can rest assure this question has been asked many of ways and answered many of ways also.
here is a short cut to catch up...
http://www.contractortalk.com/f49/po...g-3-8-a-53002/
Mr. Mike is offline
Old 06-02-2009, 11:23 PM   #3
Teetorbilt's Avatar
Take it off dry with a garden type scraper, skim, and run!
Or you can try it wet with a garden sprayer. Huge mess on the floor and very difficult to keep from tracking through the house.
Plan C (untested). Get out the 9" sander and prepare for lots of dust.
Acually you should run first. Removing popcorn rates with septic problems.
The real issue here is that popcorn was used to cover up bad lid installs which brings up the question 'Where do I go from here?'.
Albert Einstein
Teetorbilt is offline
Old 06-02-2009, 11:24 PM   #4
Lack Of All Trades
Darwin's Avatar
Trade: Professional handyman services
Lots and lots and lots of scrapin'
Darwin is offline
Old 06-02-2009, 11:39 PM   #5
Mr. Mike, i do apologize for asking this, many times asked question, but i do not visit this site on a daily basis. However i do thank you for your answer and a link to more solutions. I've done spray-scrape-skim procedure twice already, but i was curious if anyone came up with a less messy solution.
Thank you everyone.
The Following User Says Thank You to CreativePainter For This Useful Post:
Mr. Mike (06-02-2009)
Old 06-02-2009, 11:54 PM   #6
Organic Painter
Mr. Mike's Avatar
I apologize if I sounded negative, I'm new at this also and only meant to help you better by speeding up your answer, that thread was in drywall and probably would of been pretty hard to find anyways.
There might be less messy ways but this is the quickest and best for me.
Mr. Mike is offline
Old 06-10-2009, 11:53 PM   #7
the hague's Avatar
Keep in mind that acoustic ceilings dating to the early seventies could potentially contain asbestos. Don't dry scrape it, wetting it down doesn't create any more mess than keeping it dry and no dust. If its never been painted, once you get it wet (sprayer or paint roller) it'll peel right off with a flat shovel or wide drywall blade. Just put some visquene down on the floor. You'll need to texture it too as it will only have been taped and topped.
the hague is offline
Old 06-13-2009, 10:57 PM   #8
billbender's Avatar
Trade: painting/wallcovering
I've been dealing with these ceilings for awhile now. I spray em down, strap on my stilts,scrape with a 6" knife with either a mud tray or plastic roller tray directly under my knife. Fill the tray and dump in trash can, keeps the floor pretty clean.
billbender is offline
Old 06-14-2009, 12:20 AM   #9
P.R. Rescue Guy
AboveAndBeyond's Avatar
the last time we removed popcorn ceilings it was the entirety of a house, ~3k sq. ft... some of them all you can do is scrape and re-coat. however give thought to a wallpaper steamer, take it off pretty quick right to the drywall/mud. plan on re-taping the seams though.
Above & Beyond Remodeling LLC - http://www.aboveandbeyondct.com
AboveAndBeyond is offline
Old 06-22-2009, 12:24 AM   #10
jmda
jmda's Avatar
Trade: Painter
Messy job, but the fasted way is to spray with hot water and scrape. Tried it dry and it takes too much time.
jmda is offline
Old 06-22-2009, 12:53 PM   #11
A+ Texture's Avatar
Trade: Drywall, Modulars, Remodeling
Use airless sprayer to wet, garden sprayer takes to long. Then scrape with a wide knife. All-Wall.com has a scraper that attatches to a pole and it catches the texture in a bag. I removed the bag part, I just double plastic the floors, roll up the junk chuck it, then texture. And as previously stated there is a potential for asbestos and there is a procedure to follow to cover your arse.
A+ Texture is offline
Old 07-20-2009, 08:42 PM   #12
budreau
budreau's Avatar
Trade: professional contractor
what if there is asbestos ? my house has this and i've been looking at removing it. any good ways ?
thanks
budreau is offline
Old 07-21-2009, 06:46 AM   #13
paper hanger,painter
chris n's Avatar
Trade: wallpaper hanger,painter
Send a message via Yahoo to chris n
thanks
Call in a professional asbestos abatement contractor.
chris n is offline
Old 07-21-2009, 11:36 AM   #14
LetItBeLEED's Avatar
Trade: green building
You'd need a REALLY good reason to take out asbestos popcorn. Can't you just leave it the heck alone? If its damaged or you want to sell the place, I can see removing it.
The one time I ran into this, the abatement dudes said federal or state law (I forget which) required them to drop the entire ceiling (blown insulation and all). The HO was planning on remaining in the home longterm so opted to just encapsulate the popcorn and had me run furring strips, hang new panels, and apply knockdown to hide the slight waviness.
LetItBeLEED is offline
Old 07-21-2009, 01:21 PM   #15
Anti-wingnut's Avatar
The very first thing to do is to have the ceiling tested for asbestos
Anti-wingnut is offline
Old 07-21-2009, 10:20 PM   #16
budreau
budreau's Avatar
been tested - not much in it but enough. lived in this house for along time,grew up in it and just want to change some things. whats the best way to hide it that would not look like you hid something ?
thanks for all the info.
budreau is offline
Old 07-22-2009, 04:44 PM   #17
budreau
budreau's Avatar
any suggestions ?
budreau is offline
Old 07-22-2009, 06:16 PM   #18
Workaholic's Avatar
If you can't live with it like it is why not just hang some drywall on top of it?
Sean
Workaholic is offline
Old 07-22-2009, 09:45 PM   #19
budreau
budreau's Avatar
i guess i'll leave well enough alone. thanks again.
budreau is offline
Old 07-23-2009, 10:02 AM   #20
BESMAN's Avatar
sometimes this is the best thing to do when asbestos is involved...which sucks if you aren't a drywall guy.
BESMAN is offline
Quickest most efficient popcorn removal A+ Texture Drywall 18 06-05-2009 11:40 AM
Textured Ceiling Removal Old Crow Drywall 2 05-27-2009 10:48 PM
popcorn over concrete ceiling croatan Drywall 3 04-02-2009 12:09 PM
popcorn ceiling disaster lornmastro Painting & Finish Work 40 03-29-2009 09:17 AM
Popcorn Ceiling Removal / Laminate Ceiling with 3/8? plazaman Drywall 18 03-06-2009 11:45 AM
