Poly Over Shellac?
Old 06-11-2007, 11:24 AM   #1
Doer of Many Things!!!
gideond's Avatar
Trade: Paint and Floor Covering Retailer
Poly Over Shellac?
I've got a laminate floor going down in my grandmother's house. Her paneling is an old knotty pine that has ambered quite a bit over the years. I have to put some wood thresholds in with the laminate and I find that amber shellac is a very good match in color. However I know shellac is soft and i don't expect it to wear that well in a doorway. Any thoughts on putting polyurethane over top of the shellac to add some hardness. I've never tried it before and most info I can find is undecided. Any input is appreciated.
gideond is offline
Old 06-11-2007, 12:06 PM   #2
My custom title
Brushslingers's Avatar
Re: Poly Over Shellac?
Works great.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 06-11-2007, 12:47 PM   #3
gideond's Avatar
Glad to hear it. That makes my life the slightest little bit easier. Thanks.
gideond is offline
Old 06-11-2007, 04:03 PM   #4
...jammin
slickshift's Avatar
Trade: Rock Disciple
Originally Posted by Brushslingers View Post
Works great.
Interesting
Admittedly, I've never done it...as I can't imagine many others have
But it was my understanding that one needed to use de-waxed shellac if you wanted to top it off with poly
What products did you use and not have a problem with?
Signature Quote
slickshift is offline
Old 06-11-2007, 04:14 PM   #5
My custom title
Bullseye mostly... I do the same on doors all the time.
Benn
Old 06-11-2007, 04:18 PM   #6
...jammin
slickshift's Avatar
Bullseye shellac, then Bullseye poly?
Is it a look people want on their doors?
Signature Quote
Old 06-11-2007, 04:37 PM   #7
My custom title
Not by itself, normally over a stain with clear shellac or a shellac sanding sealer... but should be fine with amber.
Benn
Old 06-11-2007, 04:57 PM   #8
...jammin
slickshift's Avatar
Wild man...
So you actually stain new wood doors, shellac them, then poly them?
Freaky
I've only used (that type of) shellac to match old woodwork
Signature Quote
Old 06-11-2007, 08:45 PM   #9
gideond's Avatar
I'm very interested to see how it turns out. I'll use some steel wool on it before applying poly just to be safe. I figure since thinned shellac makes a good sanding sealer it shouldn't be a problem putting poly over it, but who knows. Not something I've needed to try before either. I prefer this method to get the color I need as opposed to intermixing stains half the day.
gideond is offline
Old 06-11-2007, 09:17 PM   #10
New York City
eastend's Avatar
Trade: historic woodwork restorations
we apply poly over shellac regularily; we usually use Seal Coat (which is a de-waxed shellac) tho, I've done it with regular amber shellac- never had a problem.
eastend is online now
Whats a good poly for tables rservices Specialty Coatings 6 06-10-2007 05:25 PM
spray shellac (tips please) painterofeveryt Painting & Finish Work 10 04-19-2007 10:15 PM
poly urethene donb1959 Painting & Finish Work 3 01-29-2007 11:37 PM
tinted poly Alkyd Painting & Finish Work 5 12-12-2006 10:00 PM
Oil base or water base poly? jhf469 Flooring 4 11-24-2006 11:36 PM
