Real facts about Peel Bond. QUV tests show that Peel Bond with topcoat outlasts oil/alkyd primers by a large margin. Peel Bond breathes unlike Mad Dog which is an elastomeric which can cause moisture entrapment. You can build surface with PB. 30 mils WFT thickness with 1 coat, dries to 9.5 mils. Easily sprayed with 517 tip and 1100-1200 PSI, try that with an elastomeric. Dries in about an hour and does not stay tacky. 5 times thicker than Peel Stop. Can be tinted. Like all of XIM's products it is very aggressive in penetration of bare wood and bonding to surfaces.
Little know fact about Peel Bond is that it has great hold out. Contractors report having to use about 30% less topcoat than with ordinary primers.
Anyone having any technical questions can contact me at
billk@ximbonder.com
