Trade: framer-inside/outside trim- asphault roofing/remoldeling
Pecky Cyprus Finish Help
any ideas on how tho finish the pecky? I'm having to make a mantel with
the pecky and wondering if anyone else has done the same. Do you fill the the holes with bar top finish stuff? or maybe just polyurathane (sp) and leave the holes? any help would be outstanding.
passingwindII
Trade: Painting, flooring
Re: Pecky Cyprus Finish Help
I've never run across the pecky cypress b4. From the pics on the intronets it looks like it has some pretty large gouges, deformities whatever you call its. If you fill it with putty you lose the pecky vibe i'd imagine. On the other hand, if you don't would the material catch hands, splinter etc??? You could use any number of wood fillers color matched and/or stainable.
We had a an exposed laminate beam and column in a remodel couple years back. Lots of splinters; not pleasing to the touch. Sanded the bejessus out of it and then gave it 4-6 coats of spar varnish. Built up pretty thick. Those columns are marine grade now baby. |
A bit abrasive.
Whenever I have filled holes in wood that was going to be used for furniture (knotty alder) I have been less than pleased with the look after I stain and seal it. If you don't want the holes and gouges, pick another breed of wood to use.
My advice: Hire a real painter to do it. |
maybe not enough info on my part. i do like the pecky i was suggesting the clear epoxy like bar top two part stuff. just to fill the top of the mantel. So in turn you would still see the pecky,just it would be flat,
passingwindII
#5 | |
A bit abrasive.
Re: Pecky Cyprus Finish HelpQuote:
Did a test, the dime was buried pretty good. I can't say that it will be much good as a filler though. Keep us updated.
Trade: painter/carpenter
Put a piece of glass on top and your done!
might look a little strange on a mantel.... That pecky is strange suff. It can look pretty nice in the right application. I did a large room that used to be Charlie Kamans( the ovation guitar guy among other things) recording studio. All the walls were t+g pecky cypress. Some of the "pecks" were a good 1/2 in. deep. Dust collectors if you don't get enough finish in there.... |
I have a piece of pecky cypress in my garage/shop . If anyone is interested I can try to post a pic. I took it home to play around with matching finishes. We pulled down the suspended ceiling and wrapped the collar ties with Knotty pine and I fuaxed the cypress look. It now has a cathedral cieling and is one of my favorite rooms in the house. We made the recording booth into a spare bedroom.
| help with finish on pecky beam | rbeck3@ec.rr.co | General Discussion | 3 | 01-29-2009 12:35 PM |
| EXT, finish choices | genecarp | Painting & Finish Work | 19 | 12-08-2008 04:47 AM |
| Dirt in Finish | banctecbobn | Flooring | 18 | 09-19-2008 06:19 PM |
| Sticky finish...Boy could I use some advice | Uuber_Framer | Flooring | 11 | 10-26-2007 04:41 PM |
| Stripping old deck finish | joedonuts | Painting & Finish Work | 26 | 06-09-2007 11:34 PM |
