Painting A Water Tower
Old 05-30-2007, 03:37 PM   #1
haskl33's Avatar
I am helping a friend out painting his water tower at his place of employment. Was wondering from professionals what to use.
The tower is about 30' high and 80' round (cylindrical).
To remove the paint - should we scrape and then power wash?
- what should we do with the rust spots?
To paint - Should we use a primer? what kind do you suggest?
- And then what type of paint? any specialty type or brand?
any information will be helpful.
I'm helping out becuase I have all the scaffolding and pressure washer. I am not a painter.
Thanks in advance for any replies.
haskl33 is offline
Old 05-30-2007, 10:25 PM   #2
Epoxy Dude
Wolverine-Eric's Avatar
Trade: Industrial Coatings & Linings
Re: Painting A Water Tower
We make products for this... so... I'm going to be really generic here to avoid breaching the Terms of Service...
Just for the record, this recommendation is what is the industry standard. We have better options which I'm not going to list... I'm going to assume this is a steel tank and not concrete... Recommendation for concrete is different...
For water towers (outside)...
First... SANDBLAST... (black Beauty) Don't drive the salts/sulfates/nitrates into the steel... White Metal Blast... 2-3 mil anchor profile!!!
Zinc Rich Primer
100% Solids Epoxy Midcoat 12-20 mils
Aliphatic Polyurethane TopCoat
Aliphatic Polyurethane Clearcoat (Optional)
For the inside you MUST use an NSF approved coating...
Some things just shouldn't be mixed... like... Kids & Paint
http://www.wolverinecoatings.com/Pic...kids&paint.gif
Wolverine-Eric is offline
Old 05-30-2007, 10:29 PM   #3
...jammin
slickshift's Avatar
Trade: Rock Disciple
I hope your friend isn't a sales associate at Wal*Mart or something
That's quite a project
Around here, private property or not, we couldn't do doinky to that w/o some EPA paperwork
Signature Quote
slickshift is offline
Old 05-31-2007, 07:04 AM   #4
Professional Painter
Richard's Avatar
Trade: Owner/Operator
Holy cow, I remember shootin' black beauty all day in the submarines. I used to like the aluminum shot too....and I understand the "white metal" comment....that was some hard work
haskl33 - basically slick told you about the legal side of it, you need to be totally in check with a job of that scale and....wolvey told you what to steps to take and what products to use
whatever you guys do, DONT WING IT...it's important to do it right
I have to be honest, you suprised me a bit when you mentioned rust spots and then asked if you would need to prime....sort of a no brainer
just powerwashing and sanding won't cut it on this job, just so you know
Rich
Richard is offline
Old 05-31-2007, 07:55 AM   #5
tkle's Avatar
John Deere green?
tkle is offline
Old 05-31-2007, 11:02 AM   #6
Professional Remodeler
firemike's Avatar
What Richard said!
I remember a few years ago an industrial complex I was working in had hired a crew to paint their water tower, not very big, about the size you are working on. 3 guys on spiders and bosun's chairs painted it in two days - start to finish. 3 days later it stormed... Sheets of paint, some as big as a sheet of letter-sized paper blew all over the complex and adjoining neighborhood. A long drawn-out legal affair developed from that one.
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline
Old 05-31-2007, 05:04 PM   #7
Woz the Painter's Avatar
And you should prime the sandblasted areas on the same day they were blasted, otherwise oxidation could occur.
Woz the Painter is offline
Old 05-31-2007, 07:25 PM   #8
plazaman's Avatar
This is def. an industrial job.
Id take wolverines Recommendation, he seems to know alot about coatings (something i wish i knew) . He is also right about sandblasting, producing a profile. The last thing you would want is to have coating failure because of poor prep.
Scaffolding is 1, then you must think about containment, you cannot blast in open air. How old is the tank? If its old enough, it may contain lead, which is another can of worms.
How will coatings be applied, brush & roller or spray?
If sandblasting isnt an option, have a coating inspector inspect the current coating and recommend a top coat.
If you need blasting done, im here !
plazaman is online now
Painting guy here...need opinion of a plumber... SeanATL Plumbing 23 05-01-2007 12:50 AM
#&*@! Water Hammer! Mike Finley Plumbing 19 02-22-2007 11:47 PM
Help Water in Basement LG2720 Construction 12 01-17-2007 02:40 AM
Hot Water Joewho Plumbing 13 11-17-2006 02:39 PM
Brick Footer and Water Proofing emtaboy Excavation & Site Work 24 07-24-2006 09:48 PM
