Painting Walls
Old 02-25-2008, 07:17 PM   #1
Plumber / Carpenter
Bill's Avatar
Trade: Virginia Building and plumbing contractor
Send a message via Yahoo to Bill
Painting Walls
How many square feet per hour can 1 man paint an 8' high wall?
Empty room
No obstructions at all
with a roller
Is it beer thirty yet
Virginia Department of Licensing
Virginia Plumbing Codes
Bill is offline
Old 02-25-2008, 07:21 PM   #2
Thag
Thag's Avatar
Trade: Home improvements
Re: Painting Walls
How long does it take a sheep to wag its tail twice?
Thag is offline
Old 02-25-2008, 07:35 PM   #3
plazaman's Avatar
Re: Painting Walls
empty room? Just rolling?
plazaman is online now
Old 02-25-2008, 08:13 PM   #4
Steve Richards's Avatar
Trade: hack painting
Re: Painting Walls
1000..maybe 1200 ..no obstructions at all isn't very common, for me anyhow. Maybe if I was painting a warehouse or something... But then I'd be spraying.
Steve Richards is offline
Old 02-25-2008, 08:24 PM   #5
Plumber / Carpenter
Bill's Avatar
Re: Painting Walls
This is a basement I am re doing. Installing drywall, prime paint then hang drop ceiling. Another man had started and you should had seen the mess. Studs sat with the 3-1/2" left to right, bottom plate on 1-1/2" edge, walls about 2" out of plumb, wall built tight around furnace, could not even get your hands between the studs and the unit, drop ceiling looked like a drunk installed it, we started to remove a few tiles and the florescent lights came crashing down because they were not secured by wire, there were open electrical connections between BX and Romex cable (No junction box) plumbing all screwed up. Terrible work. Wound up tearing it all down and starting over.
Bill is offline
Old 02-25-2008, 08:42 PM   #6
Thag
Thag's Avatar
Re: Painting Walls
What is the size of the room to be painted?
Thag is offline
Old 02-25-2008, 08:55 PM   #7
Drywall & Painting Pro
Sir Mixalot's Avatar
Trade: Hang, Finish, Texture, Paint, and Repair.
Re: Painting Walls
That guy is living the HIGH LIFE now.
Sir Mixalot is online now
Old 02-27-2008, 07:43 PM   #8
lornmastro's Avatar
Trade: interior paint contractor and window treatment workroom
Re: Painting Walls
I don't know whether I'd be smiling with electric cord running thru my pool. lol
lornmastro is offline
Why Build ICF monsterconstruc Green Building 32 09-28-2008 11:48 PM
comercial painting (walls only) profinish Painting & Finish Work 4 01-16-2008 10:00 AM
Interior painting and cold spots on the walls Dustball Painting & Finish Work 14 02-19-2007 07:26 PM
Bridging for above grade Concrete Walls ETHICS05 Construction 1 11-21-2005 12:43 PM
