Originally Posted by Wolverine-Eric
100% Acrylic!
I know of a manufacturer that sells a TON of product to do vinyl siding. They've not had a problem that I am aware of. Basically you can modify 100% acrylic with special organo-metallic adhesion promoters. The coating is also formulated to expand and contract with the vinyl siding.
Important: DO NOT PAINT IT DARKER THAN WHAT IS THERE! Also, no matter how good you think you have it covered... do 2 coats!
You need to pressure wash... make sure that you get rid of all chalking and any mold, modew, bacteria...
Obviously this post is not all inclusive... Good Prep... 100% Acrylic!
In addition to the chemists viewpoint, my practical experience with SW vinyl siding paint has always been good. Found that it actually sticks better to faded siding (after cleaning). Double 4" is less likely to warp that straight 6".
When vinyl is hung, the nails are not pounded tight, all the cuts are loose too because the vinyl has to float to compensate expansion and contraction. If hung correctly, you can go a little darker than the original color, just not really dark colors.
