Painting Tile Backsplash
Old 02-03-2009, 10:34 AM   #1
A bit abrasive.
WisePainter's Avatar
Never done it, I have standards.
That will soon change though due to an important customer's needs.
Scuff the surface apply alkyd bonding primer, topped with SW All Surface Enamel semi~gloss using a 4" mohair cover.
I don't want to spray.
Sound good?
My advice: Hire a real painter to do it.
WisePainter is offline
Old 02-03-2009, 10:39 AM   #2
Bender's Avatar
Trade: Painting Contractor
Re: Painting Tile Backsplash
I would go industrial.
Specifically on the primer.
Bender is offline
Old 02-03-2009, 10:41 AM   #3
A bit abrasive.
Which Indy primer?
Old 02-03-2009, 10:47 AM   #4
Bender's Avatar
Boy, I would have to look them up. Years ago I painted a stand up shower stall with Devoe Tile Clad( I think thats what it was. That was in probably '92)
I was very impressed with the stickabilty. It did fail a bit where I hadn't cleaned good enough, like on soap scum. But I was a knowitall kid at the time
Bender is offline
Old 02-03-2009, 10:49 AM   #5
Side Effects May Vary
ModernStyle's Avatar
Trade: Professional Painting
I have done this once, I used ICI gripper for primer, its latex but it sticks to stuff better then some alkyds. Then I top coated with ICI Devflex waterborne, it is holding up as far as I know. My first choice would have been to use an epoxy, but that wasnt possible.
ModernStyle is offline
The Following User Says Thank You to ModernStyle For This Useful Post:
nEighter (02-08-2009)
Old 02-03-2009, 10:58 AM   #6
Bender's Avatar
Then again, maybe there's a reason we've all done this only once
Bender is offline
Old 02-03-2009, 11:10 AM   #7
Traditions2's Avatar
Trade: painting and refinishing
check out midwest chemicals. I did a old asbestos floor in their porcelain enamel paint. It is used as a shuffelboard!!! Held up great!!!! Best sprayed with an hvlp but I assume you could roll it. Their products are phenomenal!!!! My website has some examples. www.traditionspainting.com I've done countertops, bathtubs, tile, floors, etc.
Traditions2 is offline
Old 02-03-2009, 06:11 PM   #8
vandy
vandyandsons's Avatar
Trade: painting, decorating, wallcovering
i would prime with SW bonding primer. it's really good
i would consider finishing with SW industrial enamel. apply with a 4" foamy. coverage blows with a foam roller and you will need 2-3 coats, but it's probably your best bet being that you don't want to spray.
vandyandsons is offline
Old 02-03-2009, 09:15 PM   #9
Da Boss....
Schmidt & Co's Avatar
Trade: Painting and wallpaper hanging contractor
XIM makes some really good bonding primers. I think UMA is the one to use on the tile.
Schmidt & Co is offline
Old 02-03-2009, 09:18 PM   #10
sparehair's Avatar
Trade: Painting, flooring
Yeah I have used their bonding primer on wall tile after abrading the tile with a palm sander. It seemed to have adhered very well. Nobody wants to paint tile but sometimes its what the customer wants/needs so we may as well give it to them.
Or you could upsell them to a retile. Probably wouldn't cost that much more than the primer, paint, and two coats of painting.
sparehair is offline
Old 02-07-2009, 08:02 PM   #11
A bit abrasive.
Hey guys, I have been weighing all of your informative responses and had narrowed it down to scuffing the surface, XIM oil bonding primer, and ProClassic alkyd semi~gloss. I was discussing my recipe with the Manager at my home store and he comp'd me a water based 2 part epoxy to mess around with. I am going to apply it directly onto the tile surface without a primer.
I will report the results on Tuesday.
Old 02-07-2009, 08:34 PM   #12
I have used the oil based version of that product, lots and lots of the oil base ........... Painted the whole inside of a YMCA with it, including the ceilings ..... epoxy overspray really burns they eyes.
Let me know how that waterborn epoxy comes out, I have a few things I wouldnt mind trying it on if it is good.
Old 02-07-2009, 08:54 PM   #13
A bit abrasive.
I really like the 2 part ArmorSeal 1000 epoxy from SW, this water based product was a complete surprise to me. I am putting it on Monday morning and I figure by Tuesday evening I will have some more info.
EDIT: The best part about this kit is that it is a 4:1 ratio instead of 1:1.
Old 02-07-2009, 09:00 PM   #14
A bit abrasive.
Heck if it is good, I may consider spraying it on trim when the alkyd ban roles through this part of the country!
Old 02-08-2009, 03:48 AM   #15
Smart phone? Scan me!
nEighter's Avatar
Trade: Painting/Framing/Drywall
I actually painted the ICI store I used to work at tile bathroom with the devflex waterborne paint.. the Gripper is balls, and is a workout takin it off of glass yeah it sticks to anything.. and GOOD. What modernstyle says is gospel
nEighter is offline
Old 02-08-2009, 11:17 AM   #16
Bender's Avatar
Wise , I don't want to be a stick in the mud but I would be leery of that stuff.
I know time is short but I would mix even a cup of it right now and test it on some of your own tile.
You probably know I'm not a big SW guy but I think that product is geared more towards commercial kitchen and bathroom sheetrock walls.
Minimum prime it with XIM 400
Just my 2 cents
Bender is offline
Old 02-08-2009, 01:08 PM   #17
A bit abrasive.
Just my 2 cents
Way to pee in my Cheerios Mr. "The Glass is Half Empty" Killjoy!
I don't make a habit of trying strange new flavors on jobs that are high profile, this is a simple sprucing up so the house will sell. If it does all go awry I will back peddle to my original plan.
I am such an adrenaline junkie when it comes to pushing materials to their limits!
Nah, that's just how I have learned everything I currently know. I have a feeling this epoxy may just have a chance to make it into my material favorites list.
Old 02-09-2009, 05:26 PM   #18
Bender's Avatar
Benders waiting for a report :taps foot, tap tap tap:
Whats the skinny?
Bender is offline
Old 02-09-2009, 05:36 PM   #19
A bit abrasive.
Whats the skinny?
Delayed.
The GC had to replace 3 irreplaceable tiles that went M.I.A. on Friday afternoon. Since he dragged his feet all day today fiddling around with the plumbing to the new granite ( btw he left the sewer pipe unplugged all weekend during the Realtor showings ) I will be applying first thing tomorrow a.m.
Yes, I am slightly bummed.
Old 02-11-2009, 09:52 PM   #20
So whats the verdict ?
Backsplash Tile around Windows... thortonwilder00 Ceramic & Stone Tile 9 01-03-2009 02:46 PM
Tile Roof Painting yourpaintstop Specialty Coatings 3 12-19-2008 05:23 PM
Pennsylvania Tile & Painting Chick MMC73 Introductions 2 09-01-2008 10:04 PM
Latest Tile Backsplash MattCoops Flooring Picture Post 20 11-19-2007 05:32 PM
Backsplash Tile Question Robie Remodeling 5 02-13-2006 09:32 AM
