Painting Test
Old 11-15-2006, 10:40 PM   #1
HUDSONVALLEYEXT's Avatar
Trade: EXTERIORS
Rewards Points: 250
Painting Test
Has any one else taking a painting test to get a certification from a local town? What kind of questions do they ask?
HUDSONVALLEYEXT is offline
Old 11-15-2006, 10:48 PM   #2
Teetorbilt's Avatar
Rewards Points: 2,000
Re: Painting Test
The license here starts SPO----- and I'm sure that there is a test. It can't be to tough, considering who is diong most of it and the results.
Most of the paint is a cover and doesn't stick, blue tape takes it off. I use green and purple tape a lot. It doesn't always work.
Albert Einstein
Teetorbilt is offline
Old 11-15-2006, 11:09 PM   #3
Trade: EXTERIORS
Rewards Points: 250
Re: Painting Test
did you have to take a test in jensen beach?
Old 11-16-2006, 05:32 PM   #4
Professional Painter
Richard's Avatar
Trade: Owner/Operator
Re: Painting Test
Nope
They probably ask you your drug of choice though
joking--I'm one of those painters that doesn't smoke anything, have a gut, and past/present drinking problem...dont know too many like me around here
Rich
Richard is offline
Old 11-16-2006, 05:37 PM   #5
Woz the Painter's Avatar
Re: Painting Test
I've taken many painting tests over the years when filling out apps. at painting contractors. Usually it's a test made up by PDCA, it's about 40 questions long. It asks stuff like what is a holiday, is green a primary color, what is a lanyard, what type of bristle brush to use with oil paint etc. It's a multiple choice test...
You cut in and I'll cut out!
Woz the Painter is offline
Old 11-16-2006, 05:41 PM   #6
Richard's Avatar
Re: Painting Test
holy cow...I took that test when applying with an old employer--I did real well--guess he took it from the pdca--well, at least I know I'm ok, since I took the test a while ago
Rich
Richard is offline
Old 11-16-2006, 06:14 PM   #7
Re: Painting Test
Originally Posted by Paintguy26 View Post
Nope
Why be a painter, then?
Old 11-16-2006, 08:02 PM   #8
Educated Applicator
MarvinWilleyJr's Avatar
Trade: Painting & Fine Finishes
Rewards Points: 286
Send a message via AIM to MarvinWilleyJr
Re: Painting Test
Had a 20 question quiz with the application for the guy I work for now. Just some basic knowledge questions, that if you are a painter you should know. I missed one out of the 20 on What do you thin shellac with. Never really worked with it, but when I got home I did a search to find out.
Also had to get certified for lead abatement and some other stuff when I was in the Union years ago.
MarvinWilleyJr is offline
Old 11-17-2006, 07:24 AM   #9
RCPainting's Avatar
Trade: Painting in Utah
Re: Painting Test
In Utah, I had to take a 50 question, 2 hour business law test. Questions varied from types of bookeeping to how often a first aid kit should be checked! The painting test was 30 questions, 2 hours. Questions also were a wide range. How long should galvanized metal be allowed to sit before painting, what are parts of paint (pigments, binder, etc.) what are correct settings for hvlp. They are administered thru Experion in several states. It is very controlled, your picture is taken, you take the test in a room on a computer under video surviellance. They have a website that explains it all and suggests books that you should read. Good Luck!
RCPainting is offline
Old 11-17-2006, 07:44 AM   #10
PAINTWERKS's Avatar
Trade: PAINTER
Rewards Points: 25
Re: Painting Test
If you guys search google for (aec daily education) there are some test from benjamin moore like paint 101 and color theory. It takes about a half hour or so. Then if you pass they will give cheap certificate to print out.
Thanks Dan
PAINTWERKS is offline
Old 11-17-2006, 08:46 AM   #11
paintr56's Avatar
Trade: paint contractor since 1974
Rewards Points: 250
Re: Painting Test
Many years ago I took a test to get e certificate of compancy from Broward county FL. A vast majority of the questions had to do with the laws. workers comp, liability, taxes, etc. Very little on painting.
Jim Bunton
paintr56 is offline
How profitable is your painting business? SeanATL Painting & Finish Work 13 04-21-2007 11:16 PM
I need work in south fl (PAINTING) ADMG32 Help Wanted or Looking For Work 2 11-07-2006 12:15 PM
Painting as part of your estimate Mike Finley Remodeling 20 05-21-2006 11:25 PM
Pricing for painting HELP!! Keefer Painting & Finish Work 9 03-16-2006 11:46 AM
Painting books pitterpat Painting & Finish Work 8 11-26-2005 10:29 AM
