regal
Guest
Posts: n/a
Painting Stair Skirts And Risers
I dont know why I didnt think of it sooner but 2yrs ago I started "clear" caulking my skirts and risers to my urethaned treads. This really helped in cutting everything in.....does any one share this technique?
#2 | |
neolitic
Guest
Posts: n/a
Re: Painting Stair Skirts And RisersQuote:
Everything I see used there has grown "hair". |
regal
Guest
Posts: n/a
right
neolitic
Guest
Posts: n/a
Brief, but informative.
regal
Guest
Posts: n/a
I know there is a joke in there but I cant fully see it.
neolitic
Guest
Posts: n/a
Sorry, no joke just a question.
Everything I've seen guys use to caulk the tread/skirt joint, collects dirt,crud, fuzz---"grows hair". ![]() Just wondered if you found something that does a better job. That's all. |
regal
Guest
Posts: n/a
oh, no see Im urethaning the oak treads, to three coats finish, once dry, Im using clear caulking and wiping with a slight damp finger & rag off the urethaned oak. This caulking goes on milky an dries clear. once dry, I can cut clean lines on my risers and skirts, painting over the clear so I have no dust problems.
neolitic
Guest
Posts: n/a
Ah hah.
regal
Guest
Posts: n/a
yeah, and Ive also taken the same recipe when I have stained trim (new const.) Raw trim put on raw plaster (wasnt given time to pre stain or paint). I will stain and urethane, clear caulk, then cut and roll. it makes for easier cleaner cutting in.
#10 | |
neolitic
Guest
Posts: n/a
I'll remember that |
regal
Guest
Posts: n/a
the pre finished stair tread ad below my post doesnt relate to my thread. To create a sharp line free hand I use clear caulking prior to painting my skirts and risers.
T.GUTIERREZ
Guest
Posts: n/a
We Use Paintable Clear On Our Stained Cabinets -around Crown&flat Moulding,helps Keep The Wood Grain Clean At Cut In Time.
regal
Guest
Posts: n/a
sounds good, also makes good cut lines against granite backsplashes.
PowerPaintingUK
Guest
Posts: n/a
Hi all,
here in the UK we use caulk between skirts n walls, door trim n walls etc. If the plastering on walls and ceilings isn't very good it can be difficult to cut in a smooth straight line and so in that instance I caulk where the top of the wall meets the ceiling then when it's dry I can cut in a nice smooth n straight line. We dont have clear caulk over here though, sounds good. ![]() edit: I also find that when I caulk I must paint over it. Any caulk that is applied and not painted eventually collects all kinds of dust etc and goes brown. Last edited by PowerPaintingUK; 12-04-2007 at 07:12 AM. |
regal
Guest
Posts: n/a
yes painting over caulk is a must
ProTouch
Guest
Posts: n/a
Thats the best tip Ive heard of in a long time! Thanks Man!!!!!
Could of used that one, a few times. Last time i decided to try using regular painters caulk and it looked great. But it was VERY time consuming to get it caulked in thin and perfect. Clear caulk Duh
paint_booger
Guest
Posts: n/a
Re: Painting Stair Skirts And Risersbrilliant!
