Old 07-01-2008, 07:07 PM   #1
SANDBLASTING & REMODELING
plazaman's Avatar
Trade: SODA BLASTING & REMODELING
Painting Stained Trims and Doors
Guys im currently bidding on a project where all the window and door casings are stained ( i think also finished with some sort of finish) where the client wants white semi-gloss.
Is scuff sand, bonding primer, and 2 coats of semi gloss my only options for the trim? There is alot of it throughout the house.
its a full repaint job, just the trim im questionable about.
pics attached, some pics looks like it stained alone without any finish.
Thanks
www.perfectocorp.com
plazaman is offline   Reply With Quote
Old 07-01-2008, 08:52 PM   #2
...jammin
slickshift's Avatar
Trade: Rock Disciple
Bonding primer?
Bonding's not the issue
Well...a little
Bleed through is more though
A nice oil will take care of the bonding issues, a nice blocker will take care of the bleed through
Zinsser's Cover Stain, BM's Fresh Start( there are several, get the quick dry oil int.), or SWP's Prep Rite (same, there's a few, get the right one), should do it
I personally like Zinsser's pigmented shellac, which will work (best)
But that's a lot of painting...and that stuff paints like pee...and stinks like...shhhhellac
I'd stick to oils for this one
Signature Quote
slickshift is offline   Reply With Quote
Old 07-01-2008, 09:07 PM   #3
plazaman's Avatar
slick, so its oil prime and my 2 coats? Anywhich way I look its 3 coats
Old 07-02-2008, 04:50 AM   #4
paper hanger,painter
chris n's Avatar
Trade: wallpaper hanger,painter
Send a message via Yahoo to chris n
Really no way around it.
chris n is offline   Reply With Quote
Old 07-02-2008, 09:56 AM   #5
Trade: Residential remodeling
Yep, Use zinsser`s oil based primer, and hit it up with two coats of semi gloss. I`d spend 1-2 days to mask and protect everything, and spray all 3 coats in 1 day .
Bleed is offline   Reply With Quote
Old 07-02-2008, 05:40 PM   #6
...jammin
slickshift's Avatar
Yup
Signature Quote
Old 07-06-2008, 11:23 PM   #7
Trade: Professional Coatings Rep
Shellac based primers are best for this application.
Shellac based primers such as BIN or SW Problock Pigmented Shellac will provide you with a sure fire stain blocker and EXCELLENT adhesion in one coat. Other, lesser quality, primers may require two coats just to block the bleed through. Dont skimp on the primer in this application.....it is the job-maker.
tcreek0022 is offline   Reply With Quote
Old 07-08-2008, 07:02 PM   #8
Likely you already know this, but in case, don't forget the putty/caulking.....
Masterpiece is offline   Reply With Quote
Old 07-09-2008, 06:51 AM   #9
Owner
Schmidt & Co's Avatar
Trade: Painting and wallpaper hanging contractor
Sand, clean, KoverStain, putty, caulk, two coats paint. Just make sure to use an oil primer...........
Schmidt & Co is offline   Reply With Quote
