Originally Posted by chaka
...I am not sure what the appropriate rate would be to charge. I obviously cannot charge Decorative artist rates.
Mmmm...no, it's not obvious why you can't charge your regular rate
Is you overhead going to be less or more?
Is your liability insurance rate going to change?
Will your helpers or you work for a different rate?
Will your bookkeeper charge a different rate for putting this transaction on the books?
Charge your regular rate
It can't be
that much less than what a Quality Painting Company charges
Anyone have a good idea of the sq. ft. rate I should be charging?
Ah...that could be an issue
I would absolutely not recommend using a sq. ft. rate for charging custom interior occupied repaints
There's not nearly enough information in the sq. ft. numbers alone to make a realistic attempt to figure out how long it's going to take you (thus how much to charge)
Occupied re-paints have waaaaaaaaaaaayyyy to many "ifs"
