Old 08-21-2007, 10:40 PM   #1
ssi
Trade: ssi home improvement
painting prices
I have a new painting project but really not sure how to price it,the job is new construction,i live in new jersey how much should i charge per square ft ,job consist of one coat primer 2coat paint, fill in nail in moldings,prime molding and paint,paint doors and windows as well. can some tell me what should i charge for thease jobs.
ssi is offline   Reply With Quote
Old 08-21-2007, 10:47 PM   #2
Trade: Paint and wallpaper
There's really no standard formula we can give you.
You need to figure out how long its going to take to complete and go from there. If you have no idea, just guess, keep track of your production rates, and material usage and you'll have a better idea of how to price the next one.
Other than that, my only advice is to charge as much as you can
phinsher is offline   Reply With Quote
Old 08-22-2007, 06:25 AM   #3
Frankawitz's Avatar
Trade: Plastering, Drywall, Painting, Woodworking, Stucco, refinishing woodwork
here's a easy way take add up all your materials, then add a zero and there you have it. now if your slow you could always say I do T&M. I charge by items, room ceiling and walls $400. doors $85. windows depending on how many lites in a sash $25. to $85 I hope this helps you. or like I said add up materials say you have $125.00 then the job would be $1,250.00 that's the easy way, good luck.
Frankawitz is online now   Reply With Quote
Old 08-22-2007, 06:37 AM   #4
ssi
prices
Thanks for the reply what about the molding and nail filler.how about the closets are they $400 as well? i started the project and i am way under bid
thats why i really need to no.and i charged the wrong amount for square footage $1.60
Old 08-22-2007, 11:23 AM   #5
Trade: painting wallcovering and drywall repair
Unfortunately, TOO many of us got in over our heads at some point in the biz and (should have) learned from it! It's not too fun to start breaking out in that cold sweat when you realize that by the time you get finished with the project, you have actually PAID THE CUSTOMER FOR THE PRIVILEGE TO DO THE DANG JOB FOR THEM!!! What really ticks me off is that if it's a commercial job, the knuckle-head company KNOWS that it has been underbid and they STILL go ahead and hire the poor sub. If they're a 'good' company they might pay a little extra for some parts of the job - but don't count on it!
My advise to the guy/gal who's never done a job of the size they are bidding on is REALLY LOOK CLOSE AT AND FIGURE YOUR COSTS! Costs are costs - no matter who is doing the job. Yeah, I know, some of the bigger contractors buy at a lower rate but I'm not talking about them. JUST BE CAUTIOUS WHEN FIGURING PRICES.
back@it is offline   Reply With Quote
Old 08-22-2007, 02:00 PM   #6
Consultant/Inspector
Mandrake's Avatar
I'd suggest doing a little exersize that will help you in the future.
Take you square footage for all your walls, and ceilings, and closets if they are included in the contract. Double for 2 coats, Triple for 3, etc.
Then do a door count, window count, Stair riser count, get linear feet of baseboard, crown molding, chair rails, etc
Once you get all your items laid out figure out an average production rate for your crew (per man) for each item. Remember the 2nd coats typically run faster.
If you are a legitimate painter you will come up with a pretty close number. Just make sure to figure breaktime and clean up into your averages.
You might end up with something like 150 sf/hr for walls, 1 hour per door (includes prep, prime, topcoat), 30 lf/hr for crown mold, etc......
From that you will arrive at your actual manhours and what your labor cost will be. Add your material cost and then you will know what it will cost YOU to do the job. How much you add on depends on your burden, overhead, and desired profit.
Hope it helps
Mndrk
Mandrake is offline   Reply With Quote
Old 08-22-2007, 03:53 PM   #7
...jammin
slickshift's Avatar
Trade: Rock Disciple
...how much should i charge per square ft ,job consist of one coat primer 2coat paint, fill in nail in moldings,prime molding and paint,paint doors and windows as well. can some tell me what should i charge for thease jobs.
Well, no body can tell you what you should charge
You know (or should know) what you overhead is, your production rates, what you need to "make" per hour to pay yourself and keep a little profit
We can guess, and suggest, but that's not a good way for you to do business
If you don't know these things, you'll have to estimate
You'll make mistakes, you'll adjust, you'll figure it out
On top of that, there's not even close to enough info there to even tell you what I would charge (which you really shouldn't be using my numbers anyway)
But I couldn't even tell you what I would charge with the lack of info
Molding:
What kind, how wide, floor, crown, chair...
Doors:
Flat, 6-panel, 12-pane glass....
Windows:
Casement, plain, fancy, muntins....
Signature Quote
slickshift is offline   Reply With Quote
Old 08-22-2007, 03:56 PM   #8
...jammin
slickshift's Avatar
Oops...it happens
Nothing learns you quicker than working for $2.76 an hour
It'll be a learning experience
Keep track of your production rates, materials, and sundries, for each part
Doors, molding, windows, walls, etc.
Use these next time
Signature Quote
Old 08-23-2007, 05:46 AM   #9
Trade: painting
Originally Posted by slickshift View Post
Oops...it happens
Man did THAT being up some sour memories...
About 25 years ago, I let a guy talk me down on a price by telling me about this lower bid he'd gotten. (I found out later he had gotten the other bid from a handyman/painter). But I was young and needed the work. I came out with about 2 bucks an hour... and a new rule about changing my original price quotes.
Thanks for reminding me, Slick!
Steve Richards is offline   Reply With Quote
Old 08-23-2007, 05:33 PM   #10
Workaholic's Avatar
Trade: Painting Contractor
3 dollars a ft
Sean
Workaholic is offline   Reply With Quote
Old 08-23-2007, 07:26 PM   #11
Trade: Professional Painting Contractor
3 is a good number right around 4-8 for high quality custom work depending on what they want.
House Painters Commercial Painting Contractors Cleveland, Ohio
http://www.welovepainting.com
http://www.cleveland-ohio-painting-contractor.com
welovepainting is offline   Reply With Quote
Old 08-25-2007, 05:41 PM   #12
Trade: Painter
paint prices
In Utah that would go for 3.50 per square foot of floor space. Interior only. Good Luck. Mike
mikenewman@fron is offline   Reply With Quote
Old 08-25-2007, 06:38 PM   #13
Traditions's Avatar
Trade: painting
is that 1.60 for floor square footage?
Traditions is offline   Reply With Quote
How profitable is your painting business? SeanATL Painting & Finish Work 13 04-21-2007 10:16 PM
SW Raising Prices Again BMAN Painting & Finish Work 22 10-24-2006 01:22 PM
Painting as part of your estimate Mike Finley Remodeling 20 05-21-2006 10:25 PM
Painting prices juddljudd Painting & Finish Work 3 03-21-2006 08:20 AM
Pricing for painting HELP!! Keefer Painting & Finish Work 9 03-16-2006 11:46 AM
