Trade: handyman
Painting Popcorn Ceiling
Hello
I know this topic has been discussed before but I cannot find it anywhere. I am probably not looking where I should but anyway do you guys roll or spray popcorn ceilings? I once rolled one and the ceiling started coming down in sheets. I despise sraying interiors but am not sure how to approach this ceiling. Comments please. Thanks again |
Trade: Squirrel Handler
Re: Painting Popcorn Ceiling
I'm not a painter but have an apartment building that I have popcorn ceilings in many of the rooms. When it needs to be painted/redone, I use a wide blade scraper and knockdown a lot of the existing and respray it, I mix that popcorn stuff with latex paint and shoot it up there, been working good for for many years. To me it seems as fast as painting, I'd be interested to hear what the pros do as well.
Some people climb mountains. I take out the trash. But we both do it for the same reason. Last edited by mickeyco; 08-01-2007 at 03:08 PM. |
Thom
I've rolled it. I've sprayed it.
I don't like spraying in a finished house but sometimes you've gotta do it. Rolling is a pain. You get one run, one direction. bring your roller back and you will bring the ceiling with it on your roller. Spraying is easier and looks a lot better when it's done. Empty the house then mask the hell out of it. A better route may be to remove the popcorn and replace it with brocade. |
Trade: Painting Contractor
I have done both as well. Usually spraying is not practicle in most repaints. To roll a popcorn ceiling you do not want to back roll much at all. if you do it will pull the texture off. Once it has been painted though you will be able to paint it like any other ceiling.
Sean |
Consultant/Inspector
Rolling is risky since it often comes off in sheets. Spraying is less risky but is often difficult to set up. I have had success with selling the client a popcorn removal and then a skip-trowel type of finish. Did it a few times with great success. Since the popcorn is likely to come down anyway you might as well get paid for it.
Mndrk |
Trade: Interior Decorator/Painter
What I always do is check to see if it has been painted before and if not paint it with oil. As the popcorn ceilings are water soluble it will absorb the latex paint and if over worked the slightest will come down. I have managed to overwork even an oil application and have some come off but never ever in sheets as you describe. Just little bits here and there. Once it's been done in oil it can be painted in latex in the future. I have heard that if your quick enough and don't backroll you can use latex which would be ok if you're painting white over white but as I almost always use a tinted paint on the ceilings using latex just wouldn't work for me.
Cheers Mary |
Mickey, If your mixing your popcorn crap with latex paint you should be able to just paint the ceilings without have to knock it down and re-apply. Yes? Guys? I thought that if it was mixed with paint , any paint, it wouldn't fall off when painted.
#8 | |
Trade: Paperhanger/painting contractor
Re: Painting Popcorn CeilingQuote:
I just knock it down a bit so there's no build up with another application, keep in mind I'm not a professional painter. I just do it between renters, it's just as fast for me to scrape and spray the whole ceiling versus painting it and the crap coming down. Right or wrong it works for me.
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
#10 | |
Side Effects May Vary
Trade: Professional Painting
#11 | ||
...jammin
Trade: Rock Disciple
It's not a big deal really, I don't fear the popcorn BUT (<-and it's a big butt) I do test/check them first (before any bids), and ask the history if known Any sign of trouble I'll waiver it (do it but have them sign a 'popcorn waiver'), or bid it as one coat oil-based primer, two coats ceiling white
Signature Quote Quote:
#12 | |
Rolling BIN on textured ceilings really isn't that bad. Sure it's runny and if you use too much pressure it's going to drip, but you learn in a hurry not to press too hard and the texture is like a sponge so it soaks in pretty good. And I'd rather roll BIN on an upainted textured ceiling ANY DAY over anything else. |
Whew! I hope you open the windows and turn on a fan. That denatured alcohol is potent stuff. lost far too many brain cells back in the day.
Mndrk |
#14 | |
Carpenter
I spray ceilings quite often, mix in some ceiling white & go to town with it. I just hate the prep time, an hour to prep & 10 minutes to spray, then another 30 minutes to clean up & remove staples. I also paint on a primer first if there is bare drywall, that way the texture don't have to be so thick.
| Ceiling painting | navco1390 | Painting & Finish Work | 22 | 11-26-2006 10:19 PM |
| Popcorn ceiling falling | dumplin1078 | Drywall | 35 | 11-08-2006 06:00 PM |
| Painting popcorn ceiling | navco1390 | Painting & Finish Work | 4 | 07-06-2006 07:43 PM |
| Popcorn Ceiling | cowtown | Painting & Finish Work | 12 | 03-30-2006 11:00 PM |
| Removing popcorn on a high pitch ceiling | AAPaint | Painting & Finish Work | 22 | 02-02-2006 09:53 AM |
