Old 11-25-2008, 08:06 PM   #1
Painting peeling off when rolled
I just came from an estimate. The customer tried to paint over a gloss paint on the ceilings that I am assuming is latex based. They told me when they tried to paint it the painted surface rolled up into there roller and it was coming off in sheets as new paint was applied. Does anyone have any ideas on what happened here? Do you think using a primer would help this situation.
Larman is offline   Reply With Quote
Old 11-25-2008, 08:43 PM   #2
A bit abrasive.
WisePainter's Avatar
It sounds like a primer was not used before the gloss paint (on the ceilings?!?) was applied.
Skim coat where the paint released, prime it up with an oil primer (to seal and prevent further peeling), and then apply top coat.
My advice: Hire a real painter to do it.
WisePainter is offline   Reply With Quote
Old 11-26-2008, 07:51 AM   #3
Frankawitz's Avatar
Trade: Plastering, Drywall, Painting, Woodworking, Stucco, refinishing woodwork
If it's a older house more then likely it's oil base paint, it needs to be sanded to break the surface, then apply your latex prime, otherwise everyttime you go to roll it out, it will peel right on to the roller skin.
www.frankawitz.net
Frankawitz is offline   Reply With Quote
Old 11-26-2008, 08:06 AM   #4
NAV
Trade: commercial building restoration
i have run into that before, it sucks. I really dont know the cause but if you check the substrate where the paint peeled it will be really chalky.
easiest way out would be to spray prime it oil (or BIN) spot patch where they messed it up and spray it with the finish coat. you can roll it if you don't back roll. the moisture in the paint is activating something under the top coat and causing the old material to fail. if you roll it, work fast - use a 18" roller.
it will probably fail down the road so do not give a warranty.
you can always fix it the correct way and remove all the loose paint, prime, patch and paint.
NAV is offline   Reply With Quote
Old 11-26-2008, 07:08 PM   #5
...jammin
slickshift's Avatar
Trade: Rock Disciple
Originally Posted by Larman
-The customer tried to paint over a gloss paint on the ceilings
-when they tried to paint it the painted surface rolled up into there roller and it -was coming off in sheets as new paint was applied.
-Does anyone have any ideas on what happened here?
Assuming you mean it's peeling to the sheetrock:
1) No primer on original paint job
2) That stupid waxy sheetrock that was popular for a few years
3) Kilz2 primer (originally)
4) Original primer sprayed w/o back-rolling
5) Original primer sprayed w/o dusting ("don't worry, the sprayer will blow the dust off")
That's just off the top of my head
Really, we need more info to zero in
If you mean the new paint peels in sheets...
Well, the list of what might have gone wrong with this DIYer will be much longer
Signature Quote
slickshift is offline   Reply With Quote
Old 11-26-2008, 07:46 PM   #6
Super Genius
Trade: No trades, no CCs. Cash or check, please.
There was a product used around here years ago called milk paint, a real PITA when you run into it. Anything water based soaks it loose, then when you back roll it comes off on the roller.
Yes, don't warranty the work.
davitk is offline   Reply With Quote
Old 11-26-2008, 08:01 PM   #7
...jammin
slickshift's Avatar
Originally Posted by davitk View Post
There was a product used around here years ago called milk paint...
..it's baaaack
Many requests for it this year
People think it's a "green" thing or something
Thankfully, I've not had to repaint it
(not having been in the biz since the 1700s...lol)
Thanks for the (retro/future) tip
Signature Quote
Old 11-30-2008, 06:22 PM   #8
blackstonepainting.com
Trade: Painter
...sand, skimcoat, sand again, latex prime (SW PrepRite Classic), topcoat (SW CHB). Can't go wrong.
blackstone is offline   Reply With Quote
Old 12-07-2008, 11:43 PM   #9
Trade: Residential building/Remodeling
Send a message via AIM to RayGoerdt
If this is in or near the kitchen it may be the grease from all the cooking collected on the ceilings. It should be scrubbed down before anything else is applied.
RayGoerdt is offline   Reply With Quote
painting over enamel stripes mfrancis Painting & Finish Work 2 11-17-2008 10:30 AM
Latex over Oil base paint is peeling iceman61 Painting & Finish Work 19 10-15-2008 11:44 PM
painting pipe fence diesel power Painting & Finish Work 14 09-06-2008 09:37 AM
Painting 60 yr old red wood> Will it hold up? RoSSco Painting & Finish Work 1 08-17-2008 08:48 AM
Painting Peeling Stucco Maderan Painting & Finish Work 7 01-13-2006 01:01 AM
