Painting Paneling
Old 10-01-2007, 08:13 PM   #1
house bldr's Avatar
Trade: general contractor
Rewards Points: 250
Painting Paneling
Need some advice from you painters out there,I bought a house to flip and it has a lot of paneling throughout that is glued on good so removal really isn't an option without a lot of work.My question is, do I need to use an oil base primer before painting or would a latex sealer such as kilz or bin work or can I just use a regular old latex primer? It is the older real wood paneling not the photo-finish stuff,not to much gloss to it.I plan to tint the primer to a close match, hoping 1 top coat would get it.Would you do it differently?Any advice is appreciated!
house bldr is offline
Old 10-01-2007, 08:43 PM   #2
...jammin
slickshift's Avatar
Trade: Rock Disciple
Rewards Points: 2,000
Re: Painting Paneling
Scuff sand, clean, one coat pigmented shellac (or possibly oil-based primer depending on the actual condition/color of the paneling)
Two coats paint
Latex Kilz or Kilz2 suck
Original Kilz is oil-based, and a decent product, but not the product you want for this project
BIN is a pigmented shellac and not latex
Yes
That's a cheesy way around doing it properly, and as it's over paneling, it's a mighty slim chance you might even 'get away with' one coat...even for a house on the market
I couldn't do it in a customers home...I never would even consider it
The other problem is, most that attempt this also buy cheap paint, which is even less likely to cover in one coat
Same color, maybe you could 'get away with it'
Over paneling, you'll be lucky if you don't need 3 coats of color
Signature Quote
slickshift is offline
Old 10-01-2007, 09:03 PM   #3
DeanV's Avatar
Trade: Painter
Rewards Points: 570
When I redo wood paneling or trim, it almost always turns into a 4 coat process, so I usually try to double prime and then 2 topcoats. I usually use something like Coverstain, an oil base primer, rather than BIN for something like this, but either one will work fine.
DeanV is offline
Old 10-02-2007, 03:52 PM   #4
Systems Fanatic
Brian's Avatar
Rewards Points: 250
We've had a couple of jobs where we primed the paneling, skim floated the grooves and seams, and then textured. When we were done it looked like drywall. It save a lot of money for the customer-- we didn't have to remove and replace moldings, hang the rock, etc.
Brian Phillips
Brian is offline
Old 10-02-2007, 04:08 PM   #5
send_it_all's Avatar
Rewards Points: 1,000
Brian Phillips
I have a customer that I am talking to right now about doing this in the master bedroom of a rather nice house. The bedroom is an addition (480 s.f) and had paneling put over unfinished drywall. I gave a price to remove paneling, tape, texture, and paint. The customer countered with "someone told me I could just skim over the grooves in the paneling and paint over that". I said "how does that save you anything?..you think a taper would rather skim coat an entire 480 sq. ' bedroom or just tape the joints?" besides that, I can walk around the room and push on the paneling in spots where it is loose. I would think that would just pop the compound out of the grooves. It is a hillbilly way to do the job UNLESS THERE IS NO ROCK BEHIND THE PANELING...then I can see it.
send_it_all is offline
Old 10-03-2007, 12:35 PM   #6
Systems Fanatic
Brian's Avatar
Rewards Points: 250
We used alot of screws to secure the paneling.
It saved the customer quite a bit of money because the paneling was 1/8" thick. Even if we used 1/4" rock, the moldings weren't going to fit properly. I gave both customer's options, and they preferred this method.
Brian Phillips
Brian is offline
Old 10-03-2007, 02:56 PM   #7
American Paint's Avatar
Trade: Painting contractor residential repaints/new construction
Rewards Points: 25
Not having rock under it is not the best way to skim coat the groves, it will for sure flex and pop the skim coats off, you need the rock under it to screw it down tight and then you can skim it and make it look great and will last for many years, nothing hill billy about this process it has been around for years and is way cheaper to have done as well.
A.P.
American Paint is offline
Old 10-03-2007, 07:27 PM   #8
Burpaz Painting's Avatar
Trade: painting
two coats of shellac and then 2 coats of finish should be a good option, wear respirators with the shellac, good luck
Burpaz Painting is offline
Old 10-04-2007, 07:45 AM   #9
Joewho's Avatar
Trade: Painter
Textured wallpaper.
Joewho is offline
How profitable is your painting business? SeanATL Painting & Finish Work 13 04-21-2007 10:16 PM
wood paneling question guys bigbrew Painting & Finish Work 11 01-14-2007 09:26 AM
Painting as part of your estimate Mike Finley Remodeling 20 05-21-2006 10:25 PM
painting painted paneling cessnapilot Painting & Finish Work 4 03-21-2006 05:21 PM
Pricing for painting HELP!! Keefer Painting & Finish Work 9 03-16-2006 10:46 AM
