Painting Over Wallpaper
Currently bidding on painting a house that requires painting over wallpaper.
1. Should it be primed,texture, and then painted 2. Or can it just be primed then painted. 3. What is a good product to use. Thanks,
Dave from Big D |
Back from the dead...
Trade: Paperhanger/Painter
Re: Painting Over Wallpaper
I don't ever paint over paper. It's too much of a risk for failure down the road. But, if I had to do it, I'd prime it with an oil primer, like BIN, or Ben Moore Alkyd Underbody. Not KILZ! First, cut out all the loose areas, or reglue them back down. Then prime. Then float out seams and otheri mperfections. Reprime the rpairs with an acrylic primer. Then paint. I'd be worried the weight of a texture would help it to pull away as it dried.
Don't do it! Strip the walls and prime.
Thanks for the advice. I'll just need to float the seams.
Dave from Big D |
#5 | |
...jammin
Trade: Rock Disciple
I'd also recommend stripping
If at all possible
Signature Quote Quote:
Trade: Builder/Remodeler- Master Electrician
Hmmm. My painters have been going over paper for years with no problems. Of course only if the paper will not come off with reasonable effort.
Loose areas remove and float, float seams. Prime with a quality oil based primer, Texture, Prime again and topcoat as needed. If you are goint to damage the wallboard removing the paper you will do more damage IMO.
www.copusconstruction.com www.etexasrentals.com www.thelakevoice.com AkA Richard Cranium |
#7 | |
Re: Painting Over WallpaperQuote:
![]() BTW, out of the 1000's of rolls I've removed over the years, less than 1% were un-removable. With proper knowledge of how to remove it correctly, it usually isn't a problem. |
#8 | ||
...jammin
It was textured paper direct to drywall I've got a bathroom coming up that was done with shelf paper I was still able to remove my test section and submit a bid I don't expect any problems ....though if I do run into any expect a call PWG! ![]() lol
#9 | |
#10 | ||
...jammin
Man that's scarier than the pic of me in the crotch pocket
Any water based paints may cause the paper to loosen and bubble. To get satisfactory results would involve priming with an oil or schellac primer, sanding and primering a second time when all is flat, filled and smooth.
IMHO, it's less expensive to strip.
#12 | |
That would be a hell of a trip charge from Mo to Tx I have tried everything on many removals and their are times when it just isn't feasible. Unless you have some trick up your sleeve I think you would have said the same thing. Why could you not sand and have smooth walls or re-paper? Usually we try to match the texture in the rest of the home. Not trying to be nasty or inflammatory but I need your trade secret But the guy is doing a job that requires bidding on painting over paper and he is from the bid "D". That means it is almost certain that the wallpaper was installed with elmers glue stolen from the framers and applied directly over new wallboard by an illegal alein.
Copus, my post wasn't necessarily directed at you, just a general statement across the board. I have heard horror stories form the land of immigrants about rolls upon rolls hung with no primer on bare drywall, so it could be more prevelant in other places than StL.
Thing is, there is no real trade secret persay. Its probably the fact that I am a paperhanger, and know all the different types of w/c, substrates they are printed on, primers, pastes, etc. When I do a removal bid, I always test a spot to determine how it was put up, and what primers/pastes were used. I use that info to make an educated guess on the best way to make it come off. Different substrates and primer/paste combos require different methods. Best trick i can tell you is the 'wrap the room' method. Protect the floor well, and soak the wall. Cut some thin mil plastic, and stick it to the wall. This will keep the moisture in instead of evaporating rapidly. After 15 minutes or so, pull back the plastic, and try to peel a spot. if its not ready, soak it again, and reapply the plastic. Be warned though, this method has a window of opportunity. Leave it on too long, and the drywall will start to delaminate. Trial and error, and keep good records on what the w/c was, what worked to take it off, and how long it took. BTW, if you remove the w/c, don't forget to wash off the paste too. |
#14 | |
I wholeheartedly agree with removal when possible....just that here sizing is pretty much an unknown. But the customer is happy because they can still get paper hung for $9.00 per roll Illegal immigration is really having an effect on the craftsman. I see them all leaving or retiring because they have had enough. It is troubling when you hear a customer bragging to you because they had a room painted for $160 and they think the guy is great. When you look around you see every roll mark and cut in....
#15 | |
#16 | |
Boy do I remember that line
| Pricing out hanging wallpaper | gary lee | Wallpaper | 51 | 10-28-2009 07:16 PM |
| wallpaper removal | lornmastro | Painting & Finish Work | 28 | 11-25-2008 08:55 PM |
| How profitable is your painting business? | SeanATL | Painting & Finish Work | 13 | 04-21-2007 11:16 PM |
| Painting over Wallpaper | RussellF | Wallpaper | 8 | 09-28-2006 09:45 PM |
| Pricing for painting HELP!! | Keefer | Painting & Finish Work | 9 | 03-16-2006 11:46 AM |
