Originally Posted by davidanbess
Thanks for the comments, basically I just wanted someone to reaffirm that oil primers will flow out better than the acrylic ones
It's not a flow thing, it's a adhesion and bleed through blocking thing
and to continue the flow thing you would need to apply an oil topcoat.
This may be true
Though the gap, if there is one, is closing
As the oils of today are getting de-spec'd for VOC reasons, and the waterbornes are getting better for the same reasons, there is not much, if any, difference between the waterborne and oil versions of the same product when it comes to "the flow thing"
