Painting Over Stained Interior Trim
The client I have wants me to paint over the interior trim that was originally stained with a "pickled wash" like stain and clear coated with what I'll assume is poly. What type of primer would you suggest to go over the trim prior to my finish paint? I was hoping to use a latex finish paint. Is problock or superbond suffice? Or do I need to get crazy and use the zinnser shellac? there is quite a bit of trim and doors to do.
Painting Contractor
Re: Painting Over Stained Interior Trim
Cover Stain
SW PrepRite Bonding Primer
Sand, and any oil based primer.
Trade: Paperhanger/painting contractor
There was a time when I would have said that the only way to go was oil primer followed by an oil topcoat. But times have changed as have the products that are available. I am now perfectly comfortable using Zinsser 123 followed by a waterborne enamel topcoat. In either case I would wash thoroughly (ammonia soution for water based or TSP for oil) rinse and sand with fine sandpaper for extra tooth.
Doer of Many Things!!!
Trade: Paint and Floor Covering Retailer
Yep a good acrylic bonding primer with work as well as oil now days. I've had plenty of people apply 1-2-3 right over high gloss poly with no sanding or cleaning and it adheres just fine. I too would recommend at least cleaning though. Sanding certainly won't hurt anything.
| How profitable is your painting business? | SeanATL | Painting & Finish Work | 13 | 04-21-2007 11:16 PM |
| I need work in south fl (PAINTING) | ADMG32 | Help Wanted or Looking For Work | 2 | 11-07-2006 12:15 PM |
| Painting as part of your estimate | Mike Finley | Remodeling | 20 | 05-21-2006 11:25 PM |
| Pricing for painting HELP!! | Keefer | Painting & Finish Work | 9 | 03-16-2006 11:46 AM |
| Painting At High Heights | Bret | Painting & Finish Work | 3 | 11-21-2005 12:50 PM |
