Old 11-19-2008, 03:17 PM   #1
Trade: Finish Carpenter
Painting over stained interior doors
Hey guys, first post; I apologize if this topic has been covered in the past. I am working on a remod, and the HO would like several interior doors, which are currently stained and coated with a dull poly to be painted to match the new base, etc. The painter has already come and gone, so I have been selected to complete this. The HO has acquired a Zinsser primer called "Cover Stain"; however, this is an oil based primer and the semi-gloss trim paint is of course a water based product. Aside from the obvious prep work on the doors (sanding, etc.), will the water based semi-gloss paint adhere to the oil based primer, or should I seek an oil based paint to complete the job?
thortonwilder00 is offline   Reply With Quote
Old 11-19-2008, 03:50 PM   #2
NAV
Trade: commercial building restoration
Zinzer is a great primer. you will be fine using a latex over it.
just make sure you do good prep.
NAV is offline   Reply With Quote
Old 11-19-2008, 06:23 PM   #3
A bit abrasive.
WisePainter's Avatar
i would prefer an alkyd for interior doors myself personally...
My advice: Hire a real painter to do it.
WisePainter is offline   Reply With Quote
Old 11-23-2008, 10:44 AM   #4
Trade: Painting and Paperhanger
Always read the lable and then do what you know works the best. Latex is fine
Jim from NJ is offline   Reply With Quote
Old 11-23-2008, 01:09 PM   #5
Workaholic's Avatar
Trade: Painting Contractor
Oil based primer is what you needed, Then a water bourne acrylic enamel/latex top coat will work without problems.
Sean
Workaholic is offline   Reply With Quote
Old 11-23-2008, 01:33 PM   #6
Agreed. Are you painting all 6 sides? Bottom may not be necessary if they are stained and finished already
boman47k is offline   Reply With Quote
painting over enamel stripes mfrancis Painting & Finish Work 2 11-17-2008 10:30 AM
Painting Crew in Ohio looking for winter work corky Help Wanted or Looking For Work 0 11-16-2008 10:46 PM
Painting Stained Trims and Doors plazaman Painting & Finish Work 8 07-09-2008 06:51 AM
Painting over stained wood ? davidanbess Painting & Finish Work 6 02-18-2008 10:18 PM
Painting over stained Interior Trim Jerdog44 Painting & Finish Work 5 10-07-2007 11:38 AM
