Painting Over Stain Exterior
Old 06-29-2008, 10:23 PM   #1
magnum217
Guest
magnum217's Avatar
Posts: n/a
I have a house that has a solid stain (pretty sure it's latex) and the HO wants it painted. Has some mildew and very little flaking. Will 1 or 2 coats of duration be enough (maybe some emulsa bond) or will this need a full coat of primer?
Old 06-30-2008, 06:59 AM   #2
premierpainter
Guest
premierpainter's Avatar
Posts: n/a
Re: Painting Over Stain Exterior
Duration straight from the can is a great finish. We use Satin. BM makes the Aura now and I think it is FAR better than the duration. No need to prime for eighter one. Two coats and see ya.
Old 08-04-2008, 07:21 PM   #3
LM Painting
Guest
LM Painting's Avatar
Posts: n/a
Why does the HO want the shakes painted as opposed to stained? Actually either will work as long as you properly prepare the surface. Killing the mildew is a must, then washing the house down after. Duration is an excellent product however you can always spot prime and go over it with ANY premium quality latex paint. Two coats over a well prepared surface should yield good long-lasting results.
Should I use paint or stain for this exterior Miniroller Painting & Finish Work 8 03-29-2010 12:29 PM
Estimating Exterior painting stockcon1 General Discussion 1 06-28-2008 02:24 PM
Cedar Shake Exterior: Paint v. Stain jen_o Painting & Finish Work 3 06-24-2008 05:27 AM
Help with exterior painting!!! tripster Painting & Finish Work 12 07-11-2007 11:02 PM
Exterior Painting Hammatime Painting & Finish Work 4 09-14-2006 08:27 PM
