Trade: home improvement
Painting Over Enamel Stripes
I am a real greeney, but need some help painting over some serious stripes. After sanding, painting, and then serious sanding over the edges again, I can still see the edges like crazy! Should I just keep painting layers and just build up the areas around the edges-sanding the edges after each layer? I thought of a skim coat, but there has got to be a better way.
Trade: commercial building restoration
Re: Painting Over Enamel Stripes
Skim Coat is the easiest way to get rid of the lines. How much time and material do you want to spend by painting and sanding over and over again?
try a palm sander to knock down the edge of the stripe, sand until it feels smooth. then go back after your first coat of finish and skim what you can still see. |
A bit abrasive.
My advice: Hire a real painter to do it. |
| Painting 60 yr old red wood> Will it hold up? | RoSSco | Painting & Finish Work | 6 | 08-13-2011 10:01 AM |
| painting pipe fence | diesel power | Painting & Finish Work | 14 | 09-06-2008 10:37 AM |
| painting stripes | Traditions | Painting & Finish Work | 17 | 03-17-2007 04:12 PM |
| Painting stripes on a gym floor?? | Dorman Painting | Painting & Finish Work | 1 | 06-01-2006 12:10 AM |
| Painting as part of your estimate | Mike Finley | Remodeling | 20 | 05-21-2006 11:25 PM |
