Painting Over Alluminum Window Casings
Old 07-24-2008, 01:58 PM   #1
MRstark44's Avatar
wondering if you use a special paint to paint over aluminum or if you would just paint with regular exterior semi-gloss?
MRstark44 is offline
Old 07-25-2008, 07:03 AM   #2
Doer of Many Things!!!
gideond's Avatar
Trade: Paint and Floor Covering Retailer
Re: Painting Over Alluminum Window Casings
Prime it with an acrylic primer like Zinsser 1-2-3 or use a DTM paint designed for adhesion to surfaces like aluminum. Don't use oil on it no matter what. Aluminum and oil don't get along well.
http://www.morrispaint.com
gideond is offline
Old 07-25-2008, 07:20 AM   #3
mikenewman@fron's Avatar
Trade: Painter
I agree. Right on. Mopaint
mikenewman@fron is offline
Old 07-25-2008, 07:35 PM   #4
paintr56's Avatar
Trade: paint contractor since 1974
100% acrylic latex with emulsa bond from flood added to the first coat, second coat 100% acrylic latex.
Jim Bunton
paintr56 is offline
Old 07-25-2008, 10:28 PM   #5
gideond's Avatar
Unless it's chalking quite a bit, Emulsa-bond is pointless. Adding an oil emulsion to the equation without a reason does more harm than good. If it is chalking I'd use Zinsser PeelStop before I'd use EB.
gideond is offline
Old 07-25-2008, 11:50 PM   #6
Teetorbilt's Avatar
Around here, remove all chalkiness with a stainless steel brush. Prime with a Zinc Chromate primer and apply the topcoat of your choice. Include a disclaimer/guarantee in your quote, not over a year if you're a rookie. 3 yrs. for a pro.
If you're going epoxies, follow ALL of the manufactures' directions.
Painting aluminum WILL ruin your day. Not now but later. Just trust me!
Albert Einstein
Teetorbilt is offline
Old 07-26-2008, 10:24 AM   #7
Da Boss....
Schmidt & Co's Avatar
Trade: Painting and wallpaper hanging contractor
We paint aluminum all the time... Its already painted from the factory, your just applying another coat. Make sure its clean! All chalk needs to be washed off. Prime bare aluminum & paint with 100% acrylic. Talk to your sales rep. if you have any questions.
Schmidt & Co is offline
Old 07-26-2008, 05:55 PM   #8
paintr56's Avatar
Emulsa bond is a dual purpose product it does emulsify chalk it also serves to increase bond over harder or glossier surfaces.
Jim Bunton
paintr56 is offline
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
Replacement Window Question? Max10 Windows, Siding and Doors 34 02-27-2010 06:15 PM
Condensation Help Patrick Windows, Siding and Doors 10 03-16-2007 09:40 AM
Window Seat and Bookshelves in Fonr of Baseboard Heating Richie-C Finish Carpentry 10 04-04-2006 09:05 PM
Painting plastic window trims saucedo80 Painting & Finish Work 6 10-17-2005 11:04 PM
