Painting An Open Basement Ceiling
Old 01-08-2018, 06:02 PM   #21
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Rewards Points: 748
Re: Painting An Open Basement Ceiling
Weve done it a few times. Two flat black and one cream color. Go flat black! We wiped all the duct work and copper with alcohol and sprayed Smart Prime (2 coats) then the black (3 coats). Have no experience with pex.
I would triple the material amount and double the labor.
We ended up getting a weed sprayer (pump type) with a long wand to get into some of the small areas. You have to cut it quite a bit, but it will work.
Its a PITA but I like the look.
The homeowner should also be made aware of noise problems you no longer have a sound barrier of any kind to the first floor.
Good luck!
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is offline
The Following User Says Thank You to DaVinciRemodel For This Useful Post:
Philament (01-09-2018)
Old 01-08-2018, 07:06 PM   #22
allaboutfun's Avatar
Trade: Painting Contractor
Rewards Points: 26
Flat black exterior house paint. One & done.
Sent from my SM-G955U using Tapatalk
allaboutfun is offline
Old 01-08-2018, 07:07 PM   #23
Rewards Points: 26
& rent a sprayer
Old 01-08-2018, 07:07 PM   #24
nickko's Avatar
Trade: remodeling-cabinet maker
Rewards Points: 707
Originally Posted by B.Johnson View Post
If your going to spray oil, wear a sock and a full faced mask. They make tear off covers for the full faced masks, when it gets to dirty to see you just replace it.
defiantly not going to spray oil. It will be water base
thanks......nicko
"Quality work for those who know the difference"
nickko is offline
Old 01-08-2018, 08:37 PM   #25
Renaissance Man
superseal's Avatar
Rewards Points: 5,308
I'm not sure oil base would be appropriate for romex...anyone feel the same?
supersealconstruction.com
superseal is online now
Old 01-09-2018, 07:08 AM   #26
B.Johnson's Avatar
Trade: Builder
Rewards Points: 1,128
thanks......nicko
I was hoping you wouldn't. That was aimed at the guys complaining about getting oil off of their faces.
Home Designer Series Software
B.Johnson is offline
rustic basement remodel blackbear Carpentry Picture Post 15 02-23-2013 06:35 PM
Painting a church with catherial ceiling danthepaintman Painting & Finish Work 2 04-15-2011 10:47 PM
attractive basement ceiling jhammer7 General Discussion 4 12-29-2010 09:34 AM
Vinyl Soffit for basement ceiling?? farmboy555 Construction 37 04-11-2010 11:23 AM
Painting beadboard ceiling Teetorbilt Painting & Finish Work 7 03-09-2009 08:59 AM
