Trade: Porch and Deck Builder
Painting New Exterior Wood Steps?
I'm building some front porch steps that will be painted. Thinking of using 2 x 6 spruce lumber for treads, and 1 x 8 pine for risers. Surfaces will be sanded and edges bullsnosed.
Should I prime and paint all the treads on both sides beofore installing them, or will just priming the undersides be sufficient. The wood is pretty knotty, so will a good Zinsser do? (I have some Zinsser alkyd stain block, or should use BIN?). They'll be painted black. Any thoughts on a good topcoat process??? |
Trade: General Contractor, Remodeler
Re: Painting New Exterior Wood Steps?
First thought is "Oh God!" I wouldn't want to try that!
I waiting for that response! Okay, full disclosure, there my own steps
I'm allowed to be reckless on my own house.
#4 | |
Trade: Paperhanger/painting contractor
Re: Painting New Exterior Wood Steps?Quote:
How about a good black stain?
Trade: Home Improvement
Definitely go with stain it bonds into the wood fibers wheras paint kinda sits on top of the surface. Stain will last much longer. Buy a cheap tester to check the moisture content if the wood feels wet and you paint all aroundit can rot from the inside out. Why black???? I would suggest Cabot australlian timber oil I like that stuff or a solid/semi color stain that is designed for porches not a siding stain as porch stain is designed to take more abuse. If your wood is dry go ahead and stain all the way around
| How profitable is your painting business? | SeanATL | Painting & Finish Work | 13 | 04-21-2007 11:16 PM |
| The 8 Steps of Painting | kanadaeh | Painting & Finish Work | 19 | 12-04-2006 05:14 PM |
| Painting steps | navco1390 | Painting & Finish Work | 6 | 07-16-2006 03:01 PM |
| Painting as part of your estimate | Mike Finley | Remodeling | 20 | 05-21-2006 11:25 PM |
| Pricing for painting HELP!! | Keefer | Painting & Finish Work | 9 | 03-16-2006 11:46 AM |
