Painting Masonite Siding
Old 09-17-2007, 10:59 AM   #1
navco1390's Avatar
Trade: painter
Is there a particular paint to use for painting Masonite siding Exterior (Need to prime and paint) Some sanding will need to be done. Any sanding tips for this type of Siding?
thanks
navco1390 is offline
Old 09-17-2007, 08:31 PM   #2
nick@nite
THINKPAINTING's Avatar
Re: Painting Masonite Siding
thanks
Is this a job you are bidding on?
THINKPAINTING is offline
Old 09-17-2007, 09:08 PM   #3
HUDSONVALLEYEXT's Avatar
Trade: EXTERIORS
We just did one this week. It was a nightmare we hit it with a scaper the cardboard and everything came off with the paint chips. I would use exteriors paint not siding stain. You should prime if there are any stains or wetspots. Masonite is crap
HUDSONVALLEYEXT is offline
Old 09-18-2007, 08:51 AM   #4
Steve Richards's Avatar
Trade: hack painting
I like to use a disc sander w/50grit...it'll feather with a little practice.
Oil base primer, acrylic latex paint
Steve Richards is offline
Old 09-20-2007, 03:56 AM   #5
Joewho's Avatar
Trade: Painter
LOL, DON'T USE 50 GRIT!!
Hudson has it right. If you bust through the paint, you're in a world of hurt.
Surface sanding is ok, but do not sand the paint off. It really is like pressed paper under there. You can't patch it without using a hardener on it first. Well, you can, somewhat. It's not advisable at all.
When moisture hits the paper it bubbles, just like the paper on drywall.
Joewho is offline
Old 09-20-2007, 10:15 AM   #6
So tell me Joe..what "patch" material do you use for masonite?
I haven't seen this siding...but I'll bet the drip edge is swollen and curled, and needs to be sanded smooth
Old 09-20-2007, 10:18 AM   #7
Here..a 2 second web search for "sand masonite siding"
http://www.house-painting-info.com/sanding.html
No way I'd use that drill-sander rig like the guy in the picture though.
I like my Makita grinder/sander...14000 RPM. That's why I can use 50 grit. It takes practice, and a light (professional) touch. Otherwise you may find yourself looking through a hole into the livingroom! J/K
I wouldn't however even touch masonite siding with a hand-scraper.
Old 09-20-2007, 03:57 PM   #8
Joewho's Avatar
Trade: Painter
My reply was to a guy who's never done it. Not taking a shot at you steve.
It does take time and practice. I would use the zinser product to harden the paper first, IF i was to attempt patching.
I've never patched exterior masonite that's been messed up like that. As far as the curling, I'd replace it rather than try to patch it.
Joewho is offline
Old 09-22-2007, 09:24 PM   #9
If it's curled, you can sand it..and not have to patch it. You can't patch it and make it last anyhow.
Sanding will only give it a few more years...but I'd MUCH rather tell the HO that, than tell them "I'm sorry, you'll have to replace those boards"...
Because if you tell them that, they'll give the job to me.
Watertight integrity of viynl siding? mci2980 Windows, Siding and Doors 71 11-24-2007 04:15 PM
Siding over Masonite fxdfast Windows, Siding and Doors 4 08-24-2007 04:34 PM
Painting Hardie Siding Paul B Painting & Finish Work 5 05-03-2007 08:12 PM
Painting Aluminum Siding Larman Painting & Finish Work 18 04-28-2007 12:05 AM
masonite siding bigbrew Painting & Finish Work 7 01-17-2007 08:11 PM
