Painting The Light Surrounds On Ext. Doors
Old 03-04-2007, 08:04 AM   #1
iowa jigman's Avatar
Trade: painting/staining
Does anyone here have a suggestion on the prep of the PVC surrounds on exterior doors. We've tried everything. The manufacture (ODL) claim "paint/stain ready" . They have told us to wipe it with a clean cloth and go. We have done this, primed, sanded, wiped with lacquor, mineral spirits, you name it, I've tried it. Even after the paint has cured you can peel the paint off with a fingernail or anything that might bump it. Thanks Roger
iowa jigman is offline
Old 03-04-2007, 09:39 AM   #2
paintr56's Avatar
Trade: paint contractor since 1974
Re: Painting The Light Surrounds On Ext. Doors
I have had success using Gripper from ICI it is a bonding primer sealer stain killer. I have seen it in one of the big box stores but I get it from ICI so I am not sure which one. It is latex and sticks well to most things. I do residential repaints so I do not do this trim brand new only after it has weathered, but a lot of it is unpainted when I get to it.
Jim Bunton
paintr56 is offline
Old 03-04-2007, 09:58 AM   #3
Thank you, this is most frustrating. I will look this product up and give it a try. I work in a door shop and sub-paint for them in my shop. We can't get these companies who make the surrounds to even give us a call-back. We are now informing the HO that we are not painting the surround if the door is painted white as the surround is white, unless they insist we paint it. Colored doors, we have no choice.
thanks Roger
Old 03-04-2007, 10:20 AM   #4
PAINTWERKS's Avatar
Trade: PAINTER
Iowa,
You also might want to try XIM bonding primer might be a little more expensive then Gripper, but I think it will work. Ive used on ceramic tile with no problem.
Thanks Dan
PAINTWERKS is offline
Old 03-04-2007, 10:45 AM   #5
MakDeco's Avatar
Trade: Painting Contractor
Jim Bunton
ICI Products are sold at Home Depot, Glidden label is probably on it but I believe its still called gripper.
MAK Deco
MakDeco is offline
Old 03-04-2007, 11:31 AM   #6
DeanV's Avatar
Trade: Painter
XIM also makes a product that is designed a a primer for plastic and vinyl that I think would work. It is solvent based.
DeanV is offline
Old 03-04-2007, 05:15 PM   #7
Painter
camaroman2125's Avatar
Trade: Painter
I haven't had a problem with bin 1-2-3. I just mask off the side lights and then shoot it with my hvlp and let it dry. Sand and then put on the first coat. sand again and then put on finish coat. I have yet to have a problem with the paint peeling
SOME PEOPLE ARE LIKE SLINKIES - NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS.
camaroman2125 is offline
Old 03-05-2007, 07:42 AM   #8
Thanks guys, I guess I haven't tried "everything" yet.
Roger
painting new steel doors Traditions Painting & Finish Work 12 06-10-2007 10:04 PM
Properly painting panel doors rocco Painting & Finish Work 10 11-16-2006 06:41 PM
painting light fixtures lowell5slide Painting & Finish Work 2 07-05-2006 08:30 PM
Painting Doors CoastalCoatings Painting & Finish Work 15 01-29-2006 07:55 AM
Price for Painting doors dwbrooks Painting & Finish Work 5 11-01-2005 08:52 PM
