Trade: Builder, renovator
Painting Latex Over Laquer Finish
Im doing a painted handrail in my own house and the spindles I bought have a white laquer finish on them from the factory...I want to change them to the same color of latex as the rest of the trim, would it be alright if i just scuffed them up, or should they be re-primed...or would it be easier just to buy them raw and prime and paint...
Trade: Painting Contractor
Re: Painting Latex Over Laquer Finish
Are you talking about regular white out of the box spindles? If so a good scuff sand and 2 coats of finish should be fine. I spray them a lot of times before they get cut and built.
Sean |
| The Following User Says Thank You to Workaholic For This Useful Post: | Vrooman (04-01-2009) |
yea they are white out of the box..they say on them white laquar
Trade: Painting, flooring
scuff and paint
Trade: Remodeling and Painting
Sand lightly and then apply one coat of COVER STAIN (fast drying oil base primer) then apply your latex finish coat. * If you put latex over the lacquer you will be able to scratch it off with your finger nail.
Good luck |
| The Following User Says Thank You to Soloplayer For This Useful Post: | Vrooman (04-01-2009) |
Organic Painter
You better prime with an oil based primer! Or you will regret it.
| The Following User Says Thank You to Mr. Mike For This Useful Post: | Vrooman (04-01-2009) |
#7 | |
Re: Painting Latex Over Laquer FinishQuote:
Why did you buy a lacquer finish spindle? Wrought iron is what every body is using here these days, at least in higher end homes. Spray them before you put them up if you have the opportunity.
Sean Last edited by Workaholic; 03-29-2009 at 03:56 AM. |
This house is not a high end home, Its going to be sold in a couple years, Nothing is real fancy in it. Im looking for raw spindles that match the newel post, but cant seem to find anything...and spraying latex with an hvlp gun sucks, i did one hand rail like that already, I don't own an airless sprayer.
| Painting business start-up questions | oneelwayfan_com | Painting & Finish Work | 56 | 02-02-2010 01:55 AM |
| Post-a-Quote | donb1959 | Painting & Finish Work | 131 | 04-21-2009 11:09 PM |
| EXT, finish choices | genecarp | Painting & Finish Work | 19 | 12-08-2008 04:47 AM |
| Level 5 finish?? | beapainter | Drywall | 3 | 09-29-2008 06:12 PM |
| Am I outrageous? | AAPaint | Painting & Finish Work | 39 | 02-16-2007 12:58 AM |
