Painting Garage Floor
Old 10-08-2006, 07:34 PM   #1
chuckdec's Avatar
Hey guys,
Got involved on re paint project in an upscale neighborhood, decks, interior wall and ceiling painting and the HO asked if I'd paint his garage floor.
Garage floor is a little over one year in service, some tire marks and oil spills, but overall doesn't look too bad. This textured concrete floor has not been painted to date.
What is a good way to prep this garage floor to accept a coating and what would you recommend for a manufacturer, product line.
Thanks,
Charlie
chuckdec is offline
Old 10-08-2006, 08:42 PM   #2
painterjim's Avatar
Re: Painting Garage Floor
http://www.hc-concrete.com/product/shieldCrete.asp
Follow the directions. Make sure the floor is clean.
Good stuff.
painterjim is offline
Old 10-08-2006, 08:56 PM   #3
Professional Painter
Richard's Avatar
Trade: Owner/Operator
Ok, as contractors in here, we mostly shy away from Home Depot. But, I have used the garage floor epoxy kit they have. It works great. I believe it comes with a cleaner. It also comes with 'sprinkles'- when spread correctly, they look good. There are other comparible kits out there, but this one I can recommend.
Rich
Richard is offline
Old 10-08-2006, 09:49 PM   #4
AFI's Avatar
Trade: Paint Contractor
Any H&C product except water base. Make sure to do a good clean.
AFI is offline
Old 10-09-2006, 01:27 AM   #5
Central Florida Painter
YourWayPainting's Avatar
Trade: Painter
We always etch the floor, and use a degreaser for any oil spots.
Make sure that it's clean, or it won't last.
Also, check on how long the product takes to cure. Down here in Florida, I tell my customers that they shouldn't walk on the product (xylene based floor stain or epoxy) for a day, put anything heavy on it for three days, and not to drive on it for a week.
A bit of overkill ... but better safe than sorry.
Hot tires will pull up a poor product, or one that hasn't cured properly.
A good paint job isn't cheap. A cheap paint job isn't good.
YourWayPainting is offline
Old 10-09-2006, 07:54 AM   #6
Painting Contractor
JMGP's Avatar
Charlie,
If you have a Devoe dealer in your area I would highly recommend using that product.
There are "some" good products out there but in my opinion there are none better than Devoe.
Even though the floor already has a profile I would still etch it. Also, you must clean the oil spills.
If you just want it quick and easy use the Devfloor 525 (2-part opoxy)
But there are many Devfloor options to choose from. Such as a high gloss urethane as a finish coat. I guess it would all depend on what the owner wants.
JMGP is offline
Old 10-10-2006, 01:45 AM   #7
Joewho's Avatar
Trade: Painter
I agree with etching, even though it's textured.
Just want to add a warning that etching involves muriatic acid. Please use utmost caution with it. It is very, very dangerous.
Joewho is offline
Old 10-10-2006, 02:20 AM   #8
747's Avatar
I agree if done properly that is a good looking floor. The sprinkles make it stand out.
747 is offline
Old 10-10-2006, 09:19 AM   #9
Pro Painter
AAPaint's Avatar
Trade: Painting Contractor
SW has an epoxy kit as well with sprinkles and all. I think that is also an H&C product and it's gauranteed not to pick up with tires, etc. If it were me, I'd try to get them to go for the xylene stain.
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline
Laminate Wood Flooring Over An Old Garage Floor mjm0073 Flooring 1 01-30-2007 10:42 PM
Painting a new garage floor? MinConst Painting & Finish Work 12 08-09-2006 05:47 PM
...continued...garage floor drain progress carlspackler Plumbing 0 05-27-2006 02:54 PM
Garage Floor Rambone Construction 8 05-10-2006 06:47 PM
Insulating garage floor bob the builder Remodeling 1 12-21-2005 10:53 PM
