Painting French Door Grilles ? - Painting & Finish Work - Contractor Talk
Old 02-24-2018, 07:37 PM   #1
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,016
Most of the time the plastic grilles are ok to leave as is.
These are quite yellow. How best to paint them ? Have never done them.
Taking the screws out, release the grille, what happens to the window...not good or what ?
Any practical way of painting these ?
Steve
We Fix Houses is offline
Old 02-24-2018, 08:28 PM   #2
Anderson's Avatar
Trade: Home improvement contractor
Rewards Points: 1,136
Re: Painting French Door Grilles ?
Liquid masking tape works great
Anderson is offline
Old 02-24-2018, 08:49 PM   #3
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,426
Take a few wood shims and stick between the glass and plastic (don't over shim, just enough to make a space), makes it way easier to paint. We always paint them : scuff with 180 grit, wipe 'em down, 2 coats of paint. That has yellowed so much I would hit it with a coat of cover stain first.
SuperiorHIP is offline
Old 02-24-2018, 09:51 PM   #4
RickP's Avatar
Trade: Door Installer
Rewards Points: 370
The door insert should stay in if you remove the interior grille. The exterior side has a factory sealant that usually takes a putty knife and some persuasion to remove. I recently replaced some door lite inserts due to the yellowed frames and one had moisture inside.
Painting French Door Grilles ?-img_20180224_204758.jpg   Painting French Door Grilles ?-img_20180224_204829.jpg
RickP is offline
Old 02-24-2018, 10:17 PM   #5
KAP's Avatar
Trade: Custom
Rewards Points: 29,480
If you were doing multiple window/doors, masking liquid works and can even act as a spot primer...
But in this case, since it's one door, leave the grill in place, tape outside of grill (2 minutes), brush or spray grill with prime/paint after quick sand.. after top coat, wait 30 minutes till it's dry to touch, run a blade around the inside of the edge of each pane... peel it off with a scraper using a clean blade (go L/R on bottom and top and Up/Down on left and right in one stroke)... gently scrape/clean up any leftovers to leave a clean edge and use a duster brush to get rid of any leftover particles...
KAP is offline
Old 02-24-2018, 10:19 PM   #6
Envelope please.........
Steve
Old 02-25-2018, 12:27 AM   #7
avenge's Avatar
Rewards Points: 3,142
A professional painter shouldn't have any issue just painting them with a brush. They are not supposed to be left unfinished, since they have yellowed they now need to be sealed.
avenge is offline
Old 02-25-2018, 02:20 AM   #8
VinylHanger's Avatar
Rewards Points: 8,206
Just time and paint. Should take 30 minutes each. Don't take the grill off. I've done some where they don't come apart and some where as soon as I took the screws out, they just fall out. Some just have a hard rubber gasket that isn't attached.
VinylHanger is offline
Old 02-25-2018, 10:12 AM   #9
Mordekyle's Avatar
Rewards Points: 3,766
I heard of painters who spray the door heavy with no masking. When dry, a razor knife cuts around each "pane" and the paint is peeled out.
Anybody done that?
Mordekyle is online now
Old 02-25-2018, 10:19 AM   #10
I think I'm going to just do the conventional paint with a 1" angle brush. I was concerned about the paint over the back of the grid, but it'll be ok. I'm still pretty good with mullions.
1 coat Cover Stain, 2 coats SW PC white.
Thanks for the all the guidance.
Steve
Old 02-25-2018, 11:50 AM   #11
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 4,766
Get some plugs for the screw holes.
Big Johnson is offline
Old 02-25-2018, 11:53 AM   #12
KAP's Avatar
Trade: Custom
Anybody done that?
Post #5... for a one-off easy enough...
KAP is offline
The Following User Says Thank You to KAP For This Useful Post:
Mordekyle (02-25-2018)
Old 02-27-2018, 04:41 PM   #13
KAP's Avatar
Trade: Custom
So how'd it go/come out?
KAP is offline
Old 02-27-2018, 07:21 PM   #14
Gotta clean up the glass tomorrow. So far looks pretty good.
Steve
The Following User Says Thank You to We Fix Houses For This Useful Post:
KAP (02-27-2018)
Old 02-27-2018, 09:05 PM   #15
Just Jennifer - The Paint
JenniferTemple's Avatar
Trade: Painter / Faux Finisher
Rewards Points: 512
The last grill I did I could easily sip light card behind and tape to the glass. I pulled the cards out as soon as it was dry to the touch but still soft. I do think much depends on how pliable the grills are. Mine pulled away from the glass fairly easy.
The picture you posted looks much like the one I did.
JenniferTemple is offline
Old 02-28-2018, 09:48 PM   #16
Here you go.
Just cut in with a 1" angle brush. A bit of razor blade scraping
Clean up with Windex. Still have to touch up a bit tomorrow.
Steve
Old 02-28-2018, 11:06 PM   #17
Rewards Points: 512
Here you go.
Looks Good!
Hello From Genius Painting Inc. Genius Painting New Member Introductions 6 05-29-2017 11:13 AM
The snow has finally melted in WI, Time to do some painting!! Austin Miller New Member Introductions 4 04-10-2016 05:27 PM
Interior Painting Question alr5100 Painting & Finish Work 8 06-21-2010 11:10 PM
Painting Shopping complex DenverPainting Painting & Finish Work 11 02-21-2010 07:13 PM
