Painting Exterior EIFS Home / Spray Gun Setup
Old 05-06-2007, 08:55 PM   #1
plazaman's Avatar
Guys,
I have to repaint an EIFS home, which has a textured acrylic based product. Can you recommend a product from the SW line that work?
I was thinking Scholastic Electrometric Coating. But I don’t think it’s an acrylic based product? (Does it matter)?
Also, I’ve always Used Brush & Roller and currently in the process of investing in a Binks Conventional painting rig. Pressure pot & gun.
Any pros and cons on this setup?
Rich
Data Sheet says Airless spray, is this considered an Airless spray setup?
http://www.amazon.com/exec/obidos/AS...4Y/dvdhills-20
http://www.amazon.com/Binks-2001-Suc...8499244&sr=1-2
plazaman is online now
Old 05-06-2007, 09:09 PM   #2
My custom title
Brushslingers's Avatar
Re: Painting Exterior EIFS Home / Spray Gun Setup
Nope.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 05-06-2007, 09:13 PM   #3
plazaman's Avatar
Originally Posted by Brushslingers View Post
Nope.
Nope as in, it doesnt matter, or it is acrylic ?
Old 05-06-2007, 10:27 PM   #4
My custom title
Meaning, it shouldn't matter.
Benn
Old 05-07-2007, 06:49 AM   #5
painterofeverything
painterofeveryt's Avatar
Trade: residential painter
Send a message via Yahoo to painterofeveryt
Any pros and cons on this setup? this is called a conventional spray gun.IT IS NOT AN AIRLESS ...google titan airless or graco airless they are the two big shooters for airless equipment.
painterofeveryt is offline
Old 05-07-2007, 09:42 AM   #6
Thom
thom's Avatar
an airless should put paint on faster with less overspray.
thom is offline
Old 05-31-2007, 10:02 PM   #7
plazaman's Avatar
http://www.sherwin-williams.com/pro/...ic_Masonry.pdf
It mentions that this coating is breathable, EIFS coatings are supposed to be non breathing systems. No moistures or vapors to enter.
Does anyone see a problem with this?
Old 06-01-2007, 03:13 PM   #8
Joewho's Avatar
Trade: Painter
It's a waterproof product. Breathability is necessary though.
Joewho is offline
Old 06-01-2007, 07:09 PM   #9
Paintpimp's Avatar
Trade: Paint
Depends on what you want. If you just want a color change. Just put on A100 or Superpaint. If you want a waterproof system. You need to use Sherlastic or Conflex.
Paintpimp is offline
Old 06-18-2007, 11:03 PM   #10
plazaman's Avatar
So you are you saying that I can use a latex top coat and not compromise the the current properties of the system?
eliminating spray gun splattering saucedo80 Painting & Finish Work 11 11-02-2010 02:47 PM
Chicago Home Repair License? Grumpy Contractor Licensing 24 09-15-2006 12:48 AM
Painting as part of your estimate Mike Finley Remodeling 20 05-21-2006 11:25 PM
Help with my painting process + Airless Spray. Phouvieng Painting & Finish Work 10 07-09-2005 01:58 AM
Spray painting questions. Drips&runs_UK Painting & Finish Work 7 04-08-2005 08:07 PM
