Trade: painting, drywall, remodeling
Painting EIFS
I am looking at bidding on painting a small motel that has EIFS. I have a couple questions. Can I use a severe weather acrylic latex and what would be best to use for surface prep. It's not a large job but I haven't painted EIFS before.
Re: Painting EIFS
Prep as usual. Low pressure detergent wash, something like sodium hypoclorite, water, and house wash will do the trick. Nothing much to it, Any quality exterior paint will do. Ive used SW A100 exterior on EIFS many times. Or if you could findout the manufacturer, they usually sell a topcoat specfically meant for color changes. If possibile, get that one, its basically is the samething AS the EIFS finish coat without the texture. So it will have the same ingredrients and what not....
#3 | |
Painting Estimator
Re: Painting EIFSQuote:
I sold Dryvit for 23 yrs. Here is what I can tell you. First, do a light power wash, even just hosing it down. If you are not doing a drastic color change, any exterior Acrylic paint will be fine with one coat. You may need to coats for the drastic color change. Look at the texture to determine the roller cover you will use. Don't bid this job without seeing the texture and knowing what the new color will be. |
Re: Painting EIFS
Thanks for the help. I appreciate it.
CT Newbie
Trade: Handyman/Lawncare/PP Work
Re: Painting EIFS
I worked as an applicator and subsequently as an inspector in the EIFS industry for over 20 years. Your best bet for EIFS is to use an EIFS manufacturer coating. Sto, Dryvit, and Parex supply the highest quality of coatings for this use. They are more expensive than paint to be sure. The reason for using them instead of latex paint is the perm rating. EIFS "breathes", bo the coating needs to as well or it will peel. Coatings designed for EIFS have 3-4 times the perm rating of latex paints.
| Painting business start-up questions | oneelwayfan_com | Painting & Finish Work | 56 | 02-02-2010 01:55 AM |
| florida painting license? | desert eagle | Contractor Licensing | 3 | 07-24-2009 08:49 AM |
| Painting and handyman, should I simplify? | englishdave | Business | 9 | 04-14-2009 07:19 PM |
| Installing replacement windows in EIFS or stucco | thatguy | Windows, Siding and Doors | 0 | 03-26-2009 11:51 AM |
| Painting Exterior EIFS Home / Spray Gun Setup | plazaman | Painting & Finish Work | 9 | 06-18-2007 11:03 PM |
