Painting Deck Spindles
Old 10-08-2007, 07:19 AM   #1
Backsight's Avatar
Trade: Site work, underground utilities, estimating & layout
What is the best way to tackle this. They are flipping me out. Not square spindles, they are decorative. Is a spray gun a good idea to help bang these things out? About 175 of them. I have a compressor.
Thanks,
Mike
Backsight is offline
Old 10-08-2007, 09:31 AM   #2
bigchaz's Avatar
Trade: Wood Restoration/Refinishing
Rewards Points: 150
Re: Painting Deck Spindles
Pressure treated?
Are they preprimed?
IF pt how wet are they?
What product are you using to paint?
If its bare pt wood you need to clean them first. If you are looking to truly paint them, then youll have to prime. Otherwise use a good solid stain preferable two coats of a self priming solid stain. Cabot pro vt would be an example.
Pro vt is some extremely thick stuff, but if you can get it to spray, spindles are very easy. Hit two sides of the spindle at a time and work your way down the line. Turn around and hit the other two sides. If your spraying you may need more than two coats depending on how heavy you're able to apply it
Charlie Soden
Apex DeckSavers
"New life for old wood"
Deck cleaning and staining Wake County
bigchaz is offline
Old 10-08-2007, 09:43 AM   #3
Deck Cleaner
PressurePros's Avatar
Trade: Deck Cleaning, Staining, Restoration
Mike, If you are using a semi transparent stain as opposed to a solid like Charlie is talking about, you can get an HVLP gun (attach to your compressor) to hit the spindles.
Ken Fenner
Pressure Washing PA
Roof Cleaning Services PA
PressurePros is offline
Old 10-08-2007, 10:01 AM   #4
Backsight's Avatar
Thanks for the help.
They are PT and dry. They looked clean to me, I just installed them in May. Should I have applied some sort of cleaning agent first or do you mean to just get any dirt/dust/webs/bugs off of them? I bought the paint at H.Depot, white satin. Behr, they said its primer and paint in one. I already put the first coat on the railings. Did about 10 spindles and figured there must be a better way of doing these. I don't mind investing in a gun because I have another deck that needs to be painted again.
I have never used a paint gun and don't know if thats just a bad idea with spindles. I imagine you can adjust the paint broadcast, narrow it down for those skinny buggers so you don't have huge waste.
Do you guys/girls think a spray gun is a good idea for this? Please say yes.
If so, do they make them specifically for this type of work? Or should I just get something that has an adjustable spay width? Since I have a compressor should I buy that type of gun or should I look for something self propelled....or does that even matter?
Thanks,
Mike
Old 10-08-2007, 01:21 PM   #5
Painting Contractor
Humble Abode's Avatar
Trade: Painting Contractor
Originally Posted by Backsight View Post
Behr, they said its primer and paint in one. Thanks,
Mike
I'm going to let others handle that one...
Anyway, I would buy a gun like the others suggest. Just get someone to stand on the other side of the railings with a drop cloth or a piece of cardboard while you spray.
It's going to take a long time with an HVLP gun too... Be sure to follow the directions on the can for thinning the "paint" you are using.
Just because some of us can read and write and do a little math, that doesn't mean we deserve to conquer the Universe. Kurt Vonnegut, (1922 - 2007) from the Novel 'Hocus Pocus'
The NAPP
Milwaukee Painting Contractor
Humble Abode is offline
Old 10-08-2007, 05:13 PM   #6
...jammin
slickshift's Avatar
Trade: Rock Disciple
Rewards Points: 2,000
First off, dump the Behr according to your local regs
Or better yet, try and get your money back
If they refuse, just leave it there
I am totally serious
That stuff is complete garbage and if it ever goes on, will look crappy, last crappy, and completely ruin any attempts at fixing it 3 years down the line
You'll have to flip/replace the boards...it's that bad, and makes that much of a mess
I'm not kidding
Then never ever ever get any coatings from HD or L again, nor believe anything they tell you about their products
Anything you buy from any actual Paint Store will kick Behr's A$$
I'd suggest Sikkens or Cabots
BM and SWP are OK too
Best application device for oil stains on installed ballusters:
small (2") Bestt Leibco Stainer (fatty)
-but that can depend on what you are using for stain also...I wouldn't use it for SWP latex stain
Signature Quote
slickshift is offline
Old 10-09-2007, 05:43 AM   #7
Backsight's Avatar
That sucks about Behr. I'm wishing I asked these questions before I started painting. I believe I'm too far into it to turn around now. Everything has its first coat....except those SOB spindles. The decking is correct deck, so thats not getting painted.
Should I switch products at this point. I'm going to do atleast one more coat, maybe two more. Probably not a good idea to be switching.
Another rookie question; Is paint sometimes referred to as stain? People keep using the word stain, although I am painting the railings white.
Thanks,
Mike
Old 10-09-2007, 06:47 AM   #8
...jammin
slickshift's Avatar
Incorrect
It would be best to switch ASAP
No...well, yes....but not by people who know what they are talking about
Decks should be stained, not painted
Railings...eh....I'd still stain them, but you already painted them
So if it's a solid stain, people might not see the dif
Signature Quote
Old 10-12-2007, 07:56 AM   #9
Backsight's Avatar
Bought a HVLP gun last night. Will be spraying like crazy tomorrow morning. Got some cardboard and test spindles set up in the backyard for testing to try to get the gun adjusted correctley. Heading off to the paint store this afternoon to get a different kind of paint and some thinning instructions. Is it worth the money to by the thinner they sell or do you guys just use water?
Old 10-12-2007, 07:24 PM   #10
Painting Contractor
For latex paint I just use water to run it through an HVLP. For oil I will use Mineral spirits for spraying and Penetrol for brushing.
The NAPP
Old 10-12-2007, 07:50 PM   #11
mikenewman@fron's Avatar
Trade: Painter
Rewards Points: 75
I like the fattest mini roller you can find. HVLP will make a mess.IMHO. I am a 30year veterin spray man but sometimes a mini roller is the easy way to go. us a heavy nap so it will wrap 50% of the picket. Mike in Moab
mikenewman@fron is offline
Old 10-12-2007, 11:05 PM   #12
Paint Pro/Faux Artisan
Da Vinci's Avatar
Trade: Painting Contractor/Faux Finisher
Rewards Points: 150
I agree- a fatty and grid in 2 gallon bucket will put the stain on faster and thicker than a sprayer any day. Roll a few spindles, then use a brush to "punch" the edges that the roller can't quite reach. It will go faster and no overspray to worry about...
Bob
Bay Area Painting Company
Da Vinci is offline
Painting Limestone Rails & Spindles plazaman Painting & Finish Work 6 07-01-2011 04:58 AM
Used the new Correct Deck CX-personal review IHI Decks & Fencing 22 07-27-2008 08:52 PM
warranty for painting a deck in chicago gjs Painting & Finish Work 6 06-09-2006 06:28 AM
Need Help: Painting Pool Deck Guardi Pro Painting & Finish Work 8 04-17-2006 09:04 PM
painting wood deck pauls painting Painting & Finish Work 16 12-14-2005 12:04 PM
