Old 04-27-2005, 04:42 PM   #1
Trade:
Painting Concrete Floors
[B]Can someone explain all the steps involved in painting a sealed concrete basement floor and tell me what materials you recommend for each step?[/b]
Finishing Touch is offline   Reply With Quote
Old 04-28-2005, 04:49 AM   #2
Pro Painter
AAPaint's Avatar
Trade: Painting Contractor
I just faced the same problem about a week ago. I had a concrete patio that had been painted before. Trick is to figure out exactly what is on the surface to begin with. Is it epoxy, urethane, or stain? I'm assuming since you say sealed it's coated or stained with something.
Anyway, what I ended up using was Armor Seal 1K water based urethane from SW to coat the patio with. I first sanded the old finish with 50 grit paper to give the urethane some good tooth, then swept clean and tacked with a damp cloth. After allowing any left over moisture to dry, I applied two coats of the urethane and it came out beautiful. The finish is hard and smooth with a nice sheen. Depending on your surface (and in my case a small patio area and the extra from a whole gallon) you really only need one good coat. Smallest size being a gallon, I had three times as much as needed, so I threw an extra coat on for good measure.
You could also look into a two part epoxy, but I wouldn't try that if you're unsure of what type of coating is on the surface to begin with. The epoxy could react and cause poor adhesion if mixed with a different type of previous coating.
Hope that helps! I'm by no means a concrete expert, but I'll give what I can! :Thumbs:
AAPaint is offline   Reply With Quote
Old 04-28-2005, 06:32 AM   #3
MODERATOR
ProWallGuy's Avatar
Trade: Paperhanger/Painter
My thoughts were if it was sealed with a clear coat, or something similar, you would want to etch the surface first. Muriatic acid
ProWallGuy is offline   Reply With Quote
Old 04-28-2005, 10:07 AM   #4
Teetorbilt's Avatar
Pro, I'm not too sure about acid in a basement, I've had the fumes attack metal in a garage with big fans going. Sanding doesn't sound like much fun either and we all know about concrete dust.
I use a primer called Skip Sand or Bondcote. It is a marine primer used to bond bottom paint to new fiberglass boats without sanding. Ever manufacturer has their own name for the stuff. It may cost a little more but sure beats the mess that the other two options create.
Albert Einstein
Teetorbilt is offline   Reply With Quote
Old 04-29-2005, 04:50 AM   #5
Bjd
Trade:
We just did one of our shop floors on Monday, the floor was pretty much abused and was never painted.
The floor was 24 x 36 and we are going to move some of my larger machines into this area, what we did was pressure wash the floor first and then we used Thoruo Seal mixed with latex floor paint.
This gave a nice sand finish and it got rid of the divots, came out nice and smooth.
Yesterday we moved 4 of the welding machines into the area, they are mounted on metal wheels and I though for sure it would do a number on the floor, however it held up great not a scratch.
BJD
Bjd is offline   Reply With Quote
Staining concrete ryan.s Masonry 12 03-05-2009 03:54 PM
structural concrete... mdshunk Masonry 3 03-05-2009 03:42 PM
new wooden floors over concrete?? remodeling joe Flooring 7 03-18-2007 11:17 PM
Concrete floors.... matuszak21 Flooring 4 01-26-2007 11:26 PM
Painting wood floors steve-in-kville Painting & Finish Work 6 12-25-2006 09:28 AM
