Captain of the Titanic
Trade: Asphalt Paving,Excavating, Masonry
Painting A Concrete Block Building
Hey guys, need a little help here.
I own 2 small commercial buildings I bought as an investment some years back. One was painted from the start and I had it re painted about 2 years ago and it seems fine. The other looks as though its never been painted and I would realy like to get it done. What should I be looking for in a proposal for this? Not price I mean what needs to be done? Like I said, there wasnt any paint i can see to speak of so I am assuming there would be no sanding / removal. I do have a small issue in the back of the building. The water from the roof runs down there. I probably need to deal with that first. The building is about 1700 sq ft and I was thinking something simple like a yellowis white. A small landscape contractor is in there now and he is a realy great tenent so I want to treat him good.
Roccies Asphalt Paving The Right Way Driveway Company If you say you cant, your a loser. If you say you wont, your a quiter. Which one do you want to be? |
Re: Painting A Concrete Block Building
Vinny If it hasn't been painted you'll need to use Block Filler on the Block to seal it, then just use a good masonary paint. Benjamin Moore has Block Filler in 5's at around $56.00.
Will there be instuctions on how much area it will cover? I would assume I should do this in the best conditions possible but what are my limitations?
Thanks in advance and sorry it took so long to answer back Vinny
Vinny -
Make sure the concrete block isn't leeching anything....minerals that discolor or 'sparkle'. I would recommend pressurewashing with a prepaint cleaner detergent to remove any impurities on the surface. Then, a block filler or... Elastomeric paint is another option. Elastomeric paint stretches when dry, so stress cracks from expansion and contraction will not break the surface as quickly. I think it would also 'fill' the small holes in the concrete pretty well too. |
| Framing into concrete ceiling | user17661 | Framing | 43 | 11-06-2011 09:46 PM |
| Fiber Optics in concrete countertops | 6stringmason | Concrete & Paving | 17 | 03-16-2011 05:49 PM |
| Anchor size for concrete block. | Chris G | Carpentry | 3 | 12-06-2006 04:42 AM |
| Parging Block | lukachuki | Masonry | 9 | 11-21-2006 08:23 PM |
| Block Work/Southern Fla. | Glasshousebltr | Construction | 0 | 03-16-2004 04:21 PM |
