Painting A Cinder Block Wall?
Old 10-30-2007, 07:44 PM   #1
gary lee's Avatar
Trade: painting contractor
I need to paint a cinder block wall that is new. Can I coat it with one of the Loxon products from S.W. to avoid from having to wait 30 days for the alkalinity (Spelling) to go down, and push forward with finsihing the wall. Thanks for any responses.
Gary
gary lee is offline
Old 10-30-2007, 07:49 PM   #2
plazaman's Avatar
Re: Painting A Cinder Block Wall?
Gary, i think loxon is the product. Id still delay as much as possible to be on the safe side.
plazaman is offline
Old 10-30-2007, 08:20 PM   #3
gary lee's Avatar
Thanks plazaman for the info. After further research it looks like Loxon conditioner is the product.
Gary
gary lee is offline
Old 01-18-2008, 09:20 AM   #4
donnag16's Avatar
Trade: painting
I have found that HC concrete stain holds up better on block than paint and it can go on directly without a primer.
donnag16 is offline
Old 01-18-2008, 09:18 PM   #5
Tin Cup's Avatar
Trade: Repair & Restoration Contractor and Specialty Graphics/Sign Installer
Dow Allguard coating for split faced block, and smooth is what i've found is the best, but not cheap.
spray and backroll. takes 2-2.5 coats depending on how you prime it.
Tin Cup
Tin Cup is offline
Vinly Siding on Cinder Block? Henry5 Windows, Siding and Doors 19 01-09-2010 06:07 PM
Cinder Block walls, block filler and a leak...question SeanATL Painting & Finish Work 9 03-09-2009 04:33 PM
Does fireplace opening in block wall opening need support? Square-One Masonry 6 11-22-2008 02:31 AM
Hanging objects off cinder block walls RobertCDF Construction 7 04-26-2007 10:07 AM
Does fireplace opening in block wall opening need support? Square-One Construction 1 02-28-2006 01:59 AM
