Old 04-03-2007, 02:54 PM   #1
Trade: painting contractor
Painting a Car Wash
bidding The painting of a Car wash. The walls are concrete block that will need to be painted with an epoxy. Right now I am leaning towards a product from Ameron called Amerlock 400. has anybody else ever done this work and if you have what products did you use?
Gary
gary lee is offline   Reply With Quote
Old 04-03-2007, 04:27 PM   #2
My custom title
Brushslingers's Avatar
Gary
Haven't done a carwash, but I did an epoxy animal shelter and a non-profit rescue, used SW two part on both, still holding up well through multiple years and washings.
Benn
Originally Posted by Brian
Brushslingers is offline   Reply With Quote
Old 04-04-2007, 09:13 PM   #3
Trade: Paint
Talk to your local SW store to make sure this system works for the carwash you are doing. I have many carwashes with this system and holds up great. Use one coat of Sw Kem Cati-Coat epoxy filler to fill all pinholes in block and follow with either Macropoxy 646 NSF or High Solids Catalyzed Epoxy to get a moisture proof system. The Macro or High Solids are also used for the inside of water tanks. That's how moisture proof they are. But this doesn't work for all projects. Have a rep look at it for you and give a recommendation.
Paintpimp is offline   Reply With Quote
Old 04-05-2007, 09:47 AM   #4
Thanks guys for the info and advice.
Gary
How profitable is your painting business? SeanATL Painting & Finish Work 13 04-21-2007 10:16 PM
Painting as part of your estimate Mike Finley Remodeling 20 05-21-2006 10:25 PM
Pricing for painting HELP!! Keefer Painting & Finish Work 9 03-16-2006 11:46 AM
Painting books pitterpat Painting & Finish Work 8 11-26-2005 10:29 AM
tips on painting baseboards with carpet floor and a tip for new painters Zeebo Painting & Finish Work 7 10-23-2005 01:20 PM
