Painting Bathroom....
Old 04-14-2007, 02:18 PM   #1
HUDSONVALLEYEXT's Avatar
Trade: EXTERIORS
Has any one ever painted bathroom tile before? I know you can I seen it on TV.... what kind of paint do you use?
HUDSONVALLEYEXT is offline
Old 04-14-2007, 02:46 PM   #2
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Re: Painting Bathroom....
Was that on Trading Spaces, or Surprise By Design?
ProWallGuy is offline
Old 04-14-2007, 03:36 PM   #3
Systems Fanatic
Brian's Avatar
We did a few many years ago. We used an epoxy and applied it with a foam roller. I wouldn't do it again. It was an absolute nightmare to clean and mask everything properly.
Brian Phillips
Brian is offline
Old 04-14-2007, 05:04 PM   #4
...jammin
slickshift's Avatar
Trade: Rock Disciple
Don't believe anything you see on those shows
They are entertainment, and to sell product for the sponsers
But aside from that, don't paint the tile
It's way over in the "Bad Idea" column
Signature Quote
slickshift is offline
Old 04-14-2007, 05:20 PM   #5
Workaholic's Avatar
Trade: Painting Contractor
LOL sounds like trading spaces
Sean
Workaholic is offline
Old 04-14-2007, 06:07 PM   #6
Trade: EXTERIORS
what do you re-surface a bathtub with?
Old 04-14-2007, 07:30 PM   #7
Teetorbilt's Avatar
I don't recommend it but if the cust. insists I call in the guys that do it for a living. BTW, call THEM when it doesn't work.
Albert Einstein
Teetorbilt is offline
Old 04-14-2007, 07:47 PM   #8
Traditions's Avatar
Trade: painting
i'm getting ready to do a job that a homeowner wants tile in their bathroom painted. SW told me they have a couple products that would work. I am very nervous to go ahead with it. THey said tile clad would work. Forgot the others they mentioned.
Traditions is offline
Old 04-14-2007, 09:35 PM   #9
Professional Painter
Richard's Avatar
Trade: Owner/Operator
maybe a bonding primer and finish with bath paint or duration? but I'm just guessing...never ran into that or saw it on tv
Richard is offline
Old 04-14-2007, 09:50 PM   #10
Teetorbilt's Avatar
If I had to.....I'd do it this way.
A) find your surface coat first. Better be a 2-part epoxy or I'm not approaching the job.
B) Follow all directions to the T. This will probably mean an air sander, silicone carbide papers and flood sanding. Be sure to hit all tile radii to the grout line without digging into the grout.
C) Clean, clean, clean.
D) Apply product of choice
Albert Einstein
Old 04-14-2007, 09:52 PM   #11
Educated Applicator
MarvinWilleyJr's Avatar
Trade: Painting & Fine Finishes
Send a message via AIM to MarvinWilleyJr
There is a paint for tiles.....we use to paint some cheap apartments and there was a guy with an HVLP that was painting the tubs with a strong smelling finish, some kind of epoxy....like reglazing them. I will see if I can find out what it was, but it turned out good. We checked them out after he finished a few and was surprised.
MarvinWilleyJr is offline
Old 04-14-2007, 10:25 PM   #12
My custom title
Brushslingers's Avatar
I've painted tile before.. wasn't that bad really... stood up for 5 years last time I saw it, used something similar to tileclad, but it was a duron product.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 04-14-2007, 10:27 PM   #13
ibsocal's Avatar
Trade: Pain
Why yes of course I paint tile all the time.and yes even a cave man can do it.dont use the stuff they sell at your local paint store.surface prep is key to a long lasting finish.if doing tile walls above bath tub or shower pan remove all soap scum and silicone/caulkings
,use ajax or comet type abrasive powered cleaners and xtra scrubbing at above and below soap dish areas and shower fixtures i use a grout file to clean out dirty grungy gruot lines use a 4" razor scraper to remove heavy soap scum and caulk.use bondo to shape and fill in damaged tile,same prep work for tile outside of wet areas except i use solvents only for cleaning walls like denatured alcohol and mek.after all is clean tight and masked off i use a wipe on primer two coats dries in about 5-15 minutes then apply 1-2 coats epoxy primer coating depending on condition of tile surface let dry about 15-20 min then top coat with 2-3 coats aliphatic acrylic poly urethane about 10-15 minutes dry time between coats.make darn sure you have a good respirator and ventillation.
oh yeah i use midwest chemicals for most of my refinishing materials and stay away from epoxies as a top coat as they will yellow with time and take 3 daze to put back in use vs 24 hours with poly.
ibsocal is offline
Old 04-14-2007, 10:30 PM   #14
Traditions's Avatar
Trade: painting
where do you get your wipe on primer. What epoxy product?
Old 04-14-2007, 10:39 PM   #15
Trade: EXTERIORS
has any one re-surfaced bath tubs?
Old 04-14-2007, 10:48 PM   #16
ibsocal's Avatar
Trade: Pain
bathtubs shower pans sinks counter tops vanities,fiberglass ceramic porcelian cultered marble all the same to me,easy money.
ibsocal is offline
Old 04-14-2007, 11:01 PM   #17
Trade: EXTERIORS
what do you use and where to you buy it ?
Bathroom Paint Problem - Strange Peeling firemike Painting & Finish Work 23 09-27-2007 07:53 PM
How profitable is your painting business? SeanATL Painting & Finish Work 13 04-21-2007 11:16 PM
Sewer Odor in upstairs bathroom Mobylola Plumbing 5 10-31-2006 07:59 PM
Painting as part of your estimate Mike Finley Remodeling 20 05-21-2006 11:25 PM
Pricing for painting HELP!! Keefer Painting & Finish Work 9 03-16-2006 11:46 AM
