Old 12-13-2007, 03:33 PM   #1
Trade: Painter
Painting Anderson prefinished interior windows
How would you go about painting the interior portion of anderson windows, the surface feels like a plastic/vinyl product (that typical grayish white color)? The trim is going BM white dove and they want the windows to match.
My current plan (which I will test on a scrap piece) is:
Sand with 220 and then prime with XIM Plastic & Vinyl Primer.
Any thoughts or other ideas? I will be spraying Graham's Ceramic Satin, which has great adhesion, so maybe the extra priming step will not be necessary.
Thanks
DeanV is offline   Reply With Quote
Old 12-13-2007, 03:47 PM   #2
Patrick's Avatar
I used to work for a moores dealer back in the day, and now I install those same windows I would recommend the underbody primer 217 I believe (the one you use for a really high gloss finish, believe it or not I used to know every single product number). That white vinyl is a really thin laminet almost like Formica. I don't blame anyone for wanting to paint it, the shop people have been getting really sloppy with the nailing, and nail filling lately on set up units.
Patrick is offline   Reply With Quote
Old 12-13-2007, 04:11 PM   #3
Trade: Painter
It almost seems like a melamine cabinet type material. My biggest concern is that it holds up long term. They should have just ordered wood for the interior side, then it could be whatever they wanted for color w/o worrying about adhesion failure.
Old 12-13-2007, 04:15 PM   #4
Patrick's Avatar
Im gonna bet these are casements? The plastic is the only option if you want pre finished, other wise its clear pine, for whatever reason they wont do painted wood on the interior jambs on a casement ( i can understand why they wont do the sash but the jambs usually don't get much weather exposure
Old 12-13-2007, 09:17 PM   #5
REGAL PAINTING
Trade: painting contractor
make sure you sign off with the homeowner, when going that route.
regal is offline   Reply With Quote
Old 12-13-2007, 09:28 PM   #6
Trade: painting
Thanks
You could always test a small area first (topcoating without priming). Be sure to clean the surface really well after 220 sanding --it'd likely help to use some type of appropriate surface cleaner (e.g. KrudKutter TSP Subtitute PrePaint --I'm unsure though).
If the topcoat adheres well now, it'll likely continue to adhere for at least a couple more years..
jack75 is offline   Reply With Quote
Old 12-13-2007, 09:44 PM   #7
Trade: Painter
I have a test board in my shop. I told the GC on this one that there is no guarantee on that it will hold up long term, but it looks like the windows do not rub when tilted in for cleaning. When opening, they rub a little, depending on where that push up on the sash.
I really do not know why in a high end home, they get that kind of window. I never had to paint it before to match the trim, usually it is just called close enough. But for high end like this one, it will not fly with the HO's.
Old 12-13-2007, 09:53 PM   #8
Patrick's Avatar
WOW they are double hungs???? Painted wood WAS an option on those. I just assumed this was a casement and he was stuck with the laminated jambs
Old 12-14-2007, 07:35 AM   #9
Trade: Painter
They are double hungs on the upstairs, crank-outs and double hungs on the main floor.
Old 12-18-2007, 10:50 PM   #10
Paint Pro/Faux Artisan
Da Vinci's Avatar
Trade: Painting Contractor/Faux Finisher
I would definitely use a good bonding primer after sanding with 220. We've done that successfully and had it hold up nicely.
Bay ARea Painting Contractor
Da Vinci is offline   Reply With Quote
Painting here in the UK PowerPaintingUK Painting & Finish Work 20 12-22-2007 04:01 AM
How profitable is your painting business? SeanATL Painting & Finish Work 13 04-21-2007 10:16 PM
Painting Question lunaassoc Painting & Finish Work 1 06-29-2006 08:34 PM
Painting as part of your estimate Mike Finley Remodeling 20 05-21-2006 10:25 PM
Pricing for painting HELP!! Keefer Painting & Finish Work 9 03-16-2006 11:46 AM
